Old 08-12-2018, 02:16 PM   #1
tzalmaves   tzalmaves is offline
Question Bashan Storm 250 Starter - repair or replace?
Hello all,
The starter on my Bashan Storm 250 went from intermittent to not working. I have 12 volts at the power lug on the starter case. Should I attempt to repair the starter or just replace it? If the latter, where can I find I find a starter for the Bashan Storm 250?
-TM
Old 08-12-2018, 05:10 PM   #2
Ariel Red Hunter's Avatar
Originally Posted by tzalmaves View Post
Hello all,
-TM
12 volts is not enough. Should be somewhere over 13. If it doesn't start working with 13 volts, try jumping the solenoid. Both the battery ground wire and the + wire to the starter are barely big enough to do the job. First improvement you can make to the bike should be heavier wires to and from the battery...ARH..
Old 08-12-2018, 10:18 PM   #3
kirbo7106's Avatar
The starter
If it comes down to needing to rebuild or replace the starter, I would recommend finding a reputable shop that rebuilds starters and alternators. With the “New” tariffs on imports, it will probably be cheaper and the turnaround time would probably be faster too!
Ride Safe!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 08-13-2018, 12:02 AM   #4
Is there a source for purchasing starters for the Bashan Storm 250?
Old 08-13-2018, 12:03 AM   #5
Ride Safe!
I'll look into this, thanks!
Old 08-13-2018, 02:10 AM   #6
pete   pete is offline
pete's Avatar
Try alliexspress.
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
