Old 02-05-2008, 09:00 PM   #1
Hondarider27   Hondarider27 is offline
Valve clearence help!!!
Anyone know what the valve clearence would be for a star 200cc atv. It dosent say in the manual! Thanks
Old 02-05-2008, 11:31 PM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
Post a photo of the motor so we can ID it.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 02-06-2008, 08:32 PM   #3
heres the best pic i got right now. I ajusted the valves to at intake .002 and exhaust at .003 and it is still ticking. It is a 200cc motor that you have to remove the head to ajust the valve clearence.
Old 02-13-2008, 08:22 PM   #4
TP   TP is offline
I have the water cooled version of this engine. I also adjusted it to 0.002" intake and 0.003" exhaust. It is very quiet when cold but ticks some when warm. My understanding is that is the way it is supposed to be on this engine since valve clearance increases as it warms up. Basically, the aluminum block expands more than the steel pushrods. You certainly do not want them too tight, since that could cause the valves not to completely close. If they don't close completely the engine will not run well and the valves will burn up.
Old 02-14-2008, 01:46 PM   #5
The valve ticking is normal for a pushrod motor. Spec is .05mm clearance if I'm not mistaken.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
