Old 09-04-2018, 10:48 PM   #1
Couple of cool parts i found -
Raining bad here so can't really work on the Vader, so I was surfing around looking at parts.Came across a cool anodized aluminum skidplate that fits Lifan 125's, so i decided to risk the cash and see if it will fit a Vader when it gets here - the holes do appear to match my engine and frame holes from what i could tell from looking at the photos, then looking at my bike here.
Here is a link to the skidplate :https://www.ebay.com/itm/4-Stroke-Di...0AAOxyDgRQ9vQP
The skidplate is also available in Gold anodizing from other suppliers , in addition to the red, black, and blue shown in that link.
The second part i found at WeBike ,a Japanese bike parts Dealer, it is for a Grom dipstick that will fit the china clones, that has a built in oil temp gauge in the top - here's a link for it WeBike has it on Sale right now for $50.00 US funds.,it's available in several colors of anodized aluminum :
https://japan.webike.net/products/22629567.html
Always nice to have an oil temp gauge on these little bikes since all we have is air cooling and it looks pretty trick , too.
Anyways just thought I'd share since I haven't seen anyone mention either of these two parts and they seem pretty trick !
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-05-2018, 01:37 AM   #2
Gh426   Gh426 is offline
Here is one for less than a 10th of the price, sensor part (needle) is 3.5" long. Yes thay say fuel temp gauge hey ESL ...
https://www.ebay.com/itm/Motorcycle-....c100005.m1851
here is a skid plate, cheaper too.
https://www.ebay.com/itm/Black-Pit-B...AAAOSw~rpZUNlG
Old 09-05-2018, 12:31 PM   #3
kirbo7106's Avatar
While you are out looking...
Hey RedCrowRides,
I don’t suppose you have come across an aftermarket shift lever for your Grom Clone?
Enjoy the Ride!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 09-05-2018, 01:22 PM   #4
@Kirbo7106
The only one I have come across so far was a universaL style that was for a pit bike in general, and i really did not like the way it fit so i put the stock one back on .It actually isn't too bad and you can jazz it up a little bit by putting one of these on : https://www.ebay.com/itm/Motorcycle-...72.m2749.l2649
As far as I know now, the Grom aftermarket shifters won't work well with the Clones because the Grom uses a linkage set up ,while ours are direct bolt on to shaft ,and the shaft itself is so far under the engine it makes for an odd fitment case for aftermarket levers ,you 'd have to find a lever with a real deep inset ,combined with a shortish forward length and so far i havent located one that is the proper shaft size.
I'm sure they exist i just havent nailed one down yet ,so I'm afraid I can't be of much help atm on that front.
If you look at this lever and notice the real long barrel that would go over the shift shaft ttps://www.ebay.com/itm/11mm-Gear-Shifter-Shift-Lever-Fit-Honda-XR-CRF-50-70-100-Pit-Bikes-110cc-125cc/122318019177?epid=898811309&hash=item1c7ab8da69 and then take into account that
the shift shaft only goes in the stock one about half way ,you'll see why the standard aftermarket design like this one : https://www.ebay.com/itm/11mm-Gear-S...sAAOSwWCdZjDIv
won't work, because it is far too " straight" and doesnt have near enough offset / inset .
It ends up being too far under the bike to be accessible ,the only one i found that "sort of" had the right configuration was so long overall you'd need to wear clown shoes to reach the toe piece in order to shift.So yeah.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-05-2018, 03:17 PM   #5
Originally Posted by kirbo7106 View Post
Hey RedCrowRides,
Enjoy the Ride!
I liked this one because its shorter. .....till i crushed it on a metal pole.
https://www.ebay.com/itm/Short-Gear-...item1c692668a9
Old 09-26-2018, 01:22 PM   #6
Chromehead22   Chromehead22 is offline
This is one I have been looking at as well. Right now I have replaced the oem one with a stock one off of my triumph Bonneville that is much shorter. It is surprising how much better it shifts to me with the short shift lever.
