CG250/Hawk CB250 XTR and other valve adj tool
Would it help folk to have the tool to adjust valves easily for CG or CB?
CB is a 10mm nut and 3.5mm square - tool is a lever n socket welded on and the adjuster nut tool thru the top - I found it super easy compared to other common tools |
#2 | |
What size is the CG250? Want to try a free sample?
10mm. Sure, why not.
I wouldn't mind getting my hand on one of those just to keep on the bike. My current setup works reasonably well - a small adjustable wrench and a small 10mm combination wrench - but it can be quite fiddley sometimes.
PM sent
That's what I do now.
Add me in for 1. Those little nuts always advance just tighter than I wanted. It's comical to watch me fidget for the right spot.... The language from the workshop is NSFW.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
#10 |
I was thinking of offering either a set of 3 or the tool for the CG or CG at $12 posted.
The feeler gauges here are very horrible I could make a small set for riders etc. The tool would be just $12 with postage but before I go gun HOO I either need to buy a adjuster for a CG or send 1 person the tool for a review etc Update - some stainless feeler gauges. This would do the Hawk etc fine I am sure - some length 4 inches plus the tool would suit owners well? Thoughts please Last edited by NzBrakelathes; 12-20-2018 at 09:19 PM. |
#11 |
Found these for sale locally
Bashan but 150 Zongshen but 200 and smaller wheels Interesting ![]() |
#13 |
that was quick but I had to leave the office early so I'll see it in the morning.
#14 |
I like the looks of the Bashan.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
#15 |
I have been on the look out for the Hawk or bike like you guys get in the USA - But no luck as the left overs I find are all some what differ and then I cannot test fit check and be sure what I sell WILL fit your bikes etc
