Old 04-06-2019, 02:38 PM   #1
Rcsup1   Rcsup1 is offline
Apollo 250 wiring help
Hi all I’m currently rewiring the bike to relocate some components. I’m going for a clean scrambler/cafe racer look. I started a couple of months ago and picked back up today. Now I have run into a snag. I have 2 wires that I have no idea we’re they go. I was really careful pulling everything apart so I am a bit
dumbfounded.
The two in question where tape some what close to the ignition switch. One is solid green the other green with a yellow stripe. They both splice off into several other wires.
Old 04-06-2019, 02:40 PM   #2
More pics
Old 04-06-2019, 04:54 PM   #3
pete   pete is offline
pete's Avatar
solid green wire is normally an earth..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-06-2019, 05:02 PM   #4
Bruces   Bruces is offline
Pete beat me to it ,green is generally ground and I don’t think anybody has posted a wiring diagram of the Apollo any chance there is anything in your owners manual ?
Old 04-06-2019, 07:07 PM   #5
I wish I have no manuals.
Old 04-07-2019, 03:24 AM   #6
humanbeing's Avatar
http://chinariders.net/showthread.ph...783#post229783
Bring the multimeter out. Use divides it into groups method & draw ur own wiring diagram.
Old 04-07-2019, 07:26 AM   #7
Its_not_a_honda   Its_not_a_honda is offline
Hard to tell from the pictures. Maybe the clutch safety switch wires? You know...the ones that make you pull the clutch in to start.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 04-07-2019, 12:57 PM   #8
Yeah that was my first thought, but the ends of the wires are male connectors that slide into something and the clutch handle terminals are male not female.
Ok correction here the brake lever is a male connection. I changed all the levers and no longer have the factory clutch lever. If anyone can take a look and let me know I would greatly appreciated. I think that may be it.
Old 04-07-2019, 12:58 PM   #9
Thank you for this!
