04-11-2019, 01:36 PM | #1 |
Mightymax Gel Battery.
Maybe I got a "bad" one. It is always possible, but I got about 9 months of use out of it and yesterday, fresh off my trickle charger it cranked twice and died. Showed 12 volts with my multimeter, but the amps were way down.
I will also admit that it is possible my high compression is putting a lot more strain on the battery (I have a starter on standby lol). I am definitely bordering on needing a compression release, and using the kickstarter makes me think I am going to break it. So, I went to the local powersports store and bought a Moose AGM battery to replace it. If this battery doesn't last I may be looking into a larger higher amp lithium battery.
04-11-2019, 01:40 PM | #2 |
That might max was a gel as stated, not litium right? I'm looking at a lithium version on ebay for my TTR since the bikemaster lithium died. Does anyone have one of those?
Piranha P190R mini-motard racer 20 Thumpstar TSX-190 12 Yamaha TTR-125 FT/ice racer 09 KTM 450 XC-F SM racer 75 CB400F Vintage rider |
04-11-2019, 07:07 PM | #3 |
I got the same battery for my hawk and neighbors' ruckus. Plan on using battery tenders on then over winter, though. You think it was the charger? Heard gel can be very touchy.
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights. 1982 Yamaha XJ1100 Maxim |
04-11-2019, 09:09 PM | #4 | ||
It's also possible I just got an old one/bad one off the shelf. It was never very strong to begin with, and I initially attributed it to my increased compression causing it to crank kinda slow. I kind of believe that scenario more after installing my new AGM battery with a fresh charge on it. Same CCA, much stronger starting.
04-11-2019, 09:24 PM | #5 |
I have the same gel battery in my Kawasaki brute Force (kymco). It's been great for a year and a half. It's never sat long though since I use the four wheeler often. I use to buy the pirate branded batteries, but last one I bought died in about two weeks. Think it had a faulty cell.
04-11-2019, 09:36 PM | #6 | |
04-11-2019, 11:00 PM | #7 |
megadan is there any added mods needed to run a lithium battery i think thats what i will need since im running so many electrical add ons and ill really be working the stator and battery with what ive added. i seen on one of your posts there would need to be a amp regulator or somthing ? since lithium ones charge different? or am i mistaken.
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
04-12-2019, 12:03 AM | #8 | |
04-12-2019, 01:44 PM | #9 |
I know what you mean Megadan. I think my compression is like 11:1 or 11.5:1. If I dont get the battery to get the engine to turn in about 4 turns I run out of power and have to kick start it. It is HARD to kick it unless I'm wearing my MX boots. But she usually starts right up.
04-12-2019, 01:44 PM | #10 |
sometimes I'll just jumpstart it from my car.
04-12-2019, 01:53 PM | #11 | |
Slightly off topic, but I can't imagine how strong the vibrations on your bike are with the compression that high. They are definitely more noticeable on my bike now vs. a stock one.
04-12-2019, 07:03 PM | #12 |
just get a Yuasa…. never got less the 6 years from one..
or a GS... same thing.. ..
04-12-2019, 08:20 PM | #13 |
I almost did, but Moose utility batteries are pretty high quality, and I have had great luck with them.
04-12-2019, 09:34 PM | #14 |
My mightymax battery is taking a chit on me too. 1 1/2 years old......guess for the price........
1983 Honda Xl600R 2016 Ducati Multistrada 1200S DVT |
04-13-2019, 02:07 PM | #15 |
Humm, this might be why mine went to crap. I just bought a Li charger and it couldn't bring it back either.
