Ignition switch problems
So i thought i had a bad battery after playing with it for a little bit i believe its the ignition switch if i jiggle the key it will come on fine anybody have similar issues and know where i can grab a replacement or fix the one i got
Hey Tarote... I would keep the money in my pocket and fix the switch.. probably no more than a wire.... I had an ignition switch problem awhile back and fixed it... instead of buying more parts...
2006 Roketa DB-07-200 Dual Sport 2007 Monte Carlo SS 5.3 2010 Challenger Hemi 5.7 2004 Isuzu Rodeo 1998 Kia Sportage 4x4 2004 Toyota Tundra 2016 Ford Escape Guitars 1970 Gibson SG mint Condition 2005 Epiphone white Custom SG Les Paul L/New Fender Banjo New Condition BC Rich Bitch - Like New\ 3 Jay Turser SG Good Condition Amps Marshall vs100 Good Condition Acoustic 261 very good condition Boss GT-6 Pedal effects Like New |
First steps for troubleshooting would be appreciated electrical is in the lower end of my skills. I only have basic knowledge.
I agree that trying to fix the current switch is worth a try, but at the same time, $35 for a complete lock set isn't that bad of a deal.
I would say a little bit of compromise is in order though. Poke around a bit, check the wiring at the switch and just look for anything obvious like a broken or loose wire or bad pin at the connector. Put the key in and turn it to the run position and maybe wiggle the wiring around instead of the key, see if it comes on. etc. I only suggest this because it would be a shame to spend $35 and wait 2-3 weeks for parts when it could have been something simple. Plus, if you buy said lock set and it ends up being something else, it would be a waste of money and you will still have to figure out what the actual issue is... Unless you are like me and don't mind having extra parts sitting around just in case.
[QUOTE=Bruces;306190]Why not tell us what bike you have then ? There are probably hundreds of Chinese bike models in circulation ,hard to help without knowing that .[/QUOTits a bashan shark
