Max. RPMs
two questions to chime in on, I want engine longevity kept in mind. Motor that will likely run 20,000 miles +
At what rpm's would you consider max. for sustained time periods? My thought based on no real data other than what CSC has posted on their posts regarding running the bikes on adventure trips. They have said many times they have run their bikes a few 100 rpm's below max. tt250 max. hp is at 7,000 rpms. They run them at 6,800 for hours on end? For short bursts, I am guessing 7-8,000 rpms is ok? |
#2 | |
The crucial thing is that your fueling is dialed in, because you will start tapping into the main jet when trying to sustain highway speeds. Being lean with the throttle cranked at high rpm for long periods of time can be unfriendly to engines.
Before I tuned my hawk, it was running pretty lean where I'm at. It would run fine, but it would get HOTTTT if ran at max for like 20 minutes or so(stock sprockets too).
However after I put the new exhaust and new carb and tuned it, It'd run max for a long time before I would worry, Definitely lots of vibrations at that rpm though. I drove like 38 miles on the highway to visit a friend when it was my only vehicle. It kept it maxed the whole way there, once I got off my legs and arms were like jelly. Took some rest to drive it back lol. I wouldnt see any reason it shouldn't be fine. If you do lots of highway, it might be smart to get an oil cooler and just gear it high for so you're not redlining at top speed. The bike reallly loves 6-7k and honestly i think would run rabid like that all day |
Like Dan said, these engine are in there happy place between the 6000-7000 rpm range. I change the front sprocket depending on what type of riding I'm doing. With a 17 tooth on from I can cruise 60-70 mph and not have the throttle pegged. An oil cooler would be a good idea if you plan on making long trips at high speeds.
mabye im crazy but after 3000 miles on the engine with no hick ups i frequent 8k rpms for extended duration's kinda have it in my head that any rpms under 9k the bike handles just fine so far. i wonder how long its gonna hold up tho so basically im trying to blow it up and it hasnt yet and shows no sign of slowing down. i never broke 7k rpms tho for the first 1000 miles. i have been playing with the idea of going to a different rear sprocket again mabye a 42 or somthing just so at max speed its closer to the 7k mark but im worried ill loose the offroad grunt
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
#6 | |
#7 | |
I really enjoyed my 43 rear sprocket, but it does give up a bit of grunt for off road riding, and it does require lots of clutch use in slow speed crawling. As Jerry mentioned, I got into the habit of swapping over to a 15 tooth front if I planned on using it more strictly off road. It takes 10 minutes to swap, and you can even toss the extra sprocket in a bag, pocket, or burrito tube.
I am basically geared for off road use, but will sometimes hit a paved road in a rural area where I can putter along at 35mph or so and let cars go faster if they catch up. Traffic volume will be very minimal. Hit a paved road run 2-3 miles then take to the off road adventure.
With my gearing 14/56 I am going to be running about 6,500 @ 35 mph and was wondering just how much I could push it in the rpm's to get 40 maybe 45 for topend speed. Geared like this I won't be full throttle, just running high rpms under essentially only a moderate load. Sounds like running 7,000 is no issue. |
