Old 07-02-2019, 06:12 PM   #1
Shane Foster   Shane Foster is offline
Bad brake switch?
My garage door was hand build by the previous owner. It doesn't open wide enough to park my buggy inside. I was keeping it outside, covered, until someone tried to steal it. I decided to break it down and put it in the garage until I can rebuild the door to open all the way.
When I put it all back together, it wouldn't start. Brake check, no light. I bypassed the brake switch and it started up. Is it possible I did something wrong when draining, refilling and bleeding the brake system?
I bought it this year and has very few hours. Surely the switch wouldn't go out that soon.
Old 07-03-2019, 11:12 AM   #2
Do you have a mechanical switch or hydraulic switch? The mechanical ones tend to corroded. Spray a little contact cleaner in it might help.
2004 Honda ST 1300
Old 07-04-2019, 10:31 AM   #3
It's hydraulic, sorry I didn't mention it. Thank you
Old 07-04-2019, 11:11 AM   #4
It may will have some air in the line or just a faulty switch. The switch works on pressure. Do the brakes pump up good and hard?
2004 Honda ST 1300
Old 07-04-2019, 08:33 PM   #5
NzBrakelathes's Avatar
bridge the 2 wires at bike n brake light should come on
Old 07-05-2019, 09:03 AM   #6
The brakes feel good. If I press the pedal and try to rock it back and forth, the brake hold it in place. I am going to try bleeding them again though. I'll try to do it today and respond later.
Old 07-05-2019, 09:06 AM   #7
That's what I meant by bypassing the switch. I just placed both wires on the same terminal of the brake switch and it started up. That is how I diagnosed the problem.
brake, brake switch, brake system
