07-18-2019, 09:26 AM | #1 |
Bashan storm 250 led headlight options.
Any one have a led replacement that works for this goofy thing? The h4 I bought fits, but there is no way to retain it. I could make it work but would like to do this less cobbled together. The h4 went in the vtx, not sure if it was an improvement or not though lol.
07-18-2019, 09:33 AM | #2 |
If it fits I would just hot glue it in place. Good luck on finding a replacement LED bulb like that.
07-18-2019, 09:45 AM | #3 |
I thought about it, but would require soldering the factory wires to the h4 plug so would have to commit to it.
Going to spend some time looking to see if anyone has a build with that base. Or measuring the housing and see if I can find one with a normal base. Or use the 3d printer I have and get creative lol.
07-18-2019, 10:05 AM | #4 |
Cravin01 did the LED mod.
07-18-2019, 07:15 PM | #5 |
I did my own led mod into double round scrambler lights. It helped the battery a ton.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
08-05-2019, 10:38 AM | #6 |
Must have missed the notification for your post.
I had saw that, and with the bulb i have i can do the same thing by gluing it, just wasn't sure how it would perform in that housing. I should have swapped it when i did the shift indicator install but i didn't think about it. When i add my usb adapter i might do it. I had zero luck finding a dual mode (hi/low beam) in that bulb base, just lots of single mode. Too bad Bashan didn't use a automotive style bulb.
08-06-2019, 11:25 PM | #7 |
Humm...
US $14.80 22%OFF | Plug&play 30W 3200lm MEC Ba20d LED Motorcycle Headlight H6 Scooter Motorbike Headlamp Light Bulb Accessories 6000K White 12/24V https://s.click.aliexpress.com/e/cYBc2frS
08-12-2019, 08:51 AM | #8 |
Finally found some on Amazon. So far it fits and high/low beam works but i haven't had a chance to try it out on road at night. I can tell you it's brighter than the stock bulb so it should be an improvement but i don't know if it will be "good". Ill post some pictures tonight after it gets dark.
https://www.amazon.com/EverBrightt-B...s%2C181&sr=8-3
2020 Triumph Tiger 900 rally. 2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust. 2019 Taotao 110b boulder atv. The "arm breaker" lol 2007 Honda VTX 1300R. 1974 Suzuki tm125, work in progress 2001 Suzuki Drz 400s. Last edited by duck9191; 08-12-2019 at 12:45 PM. |
08-12-2019, 09:39 PM | #9 |
Well I didn't think it was much brighter but damn. Didn't take it down the road, had a few adultl beverages with dinner lol.
New high and low beam, old low beam is last.
08-12-2019, 09:41 PM | #10 |
This was the high beam before.
