07-24-2019, 12:59 PM | #1 |
What’s a stock Vader like?
I’m thinking of getting a Vader to putt around and was wondering how is a natural Vader? Is It a ok bike stock? I would like to have some fun with it before I figure out how to change a carb and all that but I don’t know if it is going to be unusable stock, also what bolts do I have to loctite specifically? Or is it every bolt I see.
07-24-2019, 07:42 PM | #2 |
First question back to you would be what is your intended use? As in, what kind of roads/streets/boulevards/etc. are you intending? 55 MPH and faster freeways, for several miles, are probably not quite this bike's forte. Even modified, although you could probably get away with a 55 MPH road from time to time for shorter trips.
07-24-2019, 10:12 PM | #4 |
Stock should work for those kinds of speeds. The next reason to do light modification(s) would be for reliability reasons. The stock carb is reported to not be reliable, BUT people generally change out the carb and exhaust before their bike is broken in; in other words, I don't recall any member having a broken in bike complaining about having fuel delivery issues. Most change their carb because most want/need/desire a bike that can hit 50+ mph. As far as locktite goes, yes you want to locktite as many bolts as you can get your hands on, but there are some bolts that members have changed out for genuine Honda Grom bolts. I am sure you will get a few to chime in on this thread.
07-25-2019, 07:19 AM | #5 |
I have 2 Hellcats. Essentially same bike as the Vader. Only performance mod is a 17t front sprocket. I did get better performance after cleaning stock carbs and as they break in.
If you are willing to spend the time correcting quality/assembly issues, these are great toys. See mine and others posts. |
07-25-2019, 07:56 AM | #6 |
My bike ran fine on the stock carb. would run 55 mph for extended periods of time. The 17 tooth sprocket is a must though. Even if you are not mechanically inclined it is a simple mod. As far as locktite, I would do every bolt you can ha ha. I made the mistake of not using loctite on some of my exhaust bolts and it ended up snapping the studs, needed a new motor.
07-25-2019, 09:23 AM | #7 |
Ok, what sprocket does the bike come with, and does the 17 tooth hurt the torque or is the drawback so little it dosent matter
07-25-2019, 09:32 AM | #8 |
It mattered for me....first gear was practically useless stock. After sprocket it made a big difference.
BD125-15 |
07-25-2019, 01:02 PM | #9 |
Switching to the 17t front sprocket wont noticeably affect the torque unless you plan on stunting .,and it will make super low / short first gear actually usable One thing i would strongly recommend is, if the gas in your area has ethanol added , and almost all gas does, you need to replace the stock gas lines out ASAP to a silicone based line, the ethanol in our gas eats up the fuel line from the inside causing it to flake which can stop up your fuel filter or worse, carb jets.
It's a really cheap fix for 2 to 5 bucks. Other than these two mods there is no reason you cant enjoy a Vader right out of the box ,and you can do both for under 20 bucks total.,where you go from there is up to you.
07-25-2019, 02:43 PM | #11 |
Call Kronik. You will be glad you did! They will give you a good price on the Vader, as well as have mucho knowledge on them. Pete, the owner, told me he is kind of the de facto r & d for Boom/Baodiao, and having some glimpses into the Chinese motorsports industry, I believe him. These bikes used to be notorious for having issues (mostly with electronics) out of the box (although the members were able to sort them out), but now, not so much. Pete said a lot of the quality issues were sorted out at the factory thanks to his constant input here in L.A.
07-25-2019, 11:47 PM | #12 |
I second Culcune, by all means call Kronik, they have never let me down and i have used them a lot. And , because they deal directly with Vaders you can rest assured the sprocket WILL fit . I'd buy the Vader from them if possible, but they will help you even if you get it from Venom Motorsports . All that said a 7t sprocket for a Grom off ebay "should " fit, mine did with no problems, but i didnt know about Kronik when i got it or i would have gotten it from them .
07-26-2019, 04:06 AM | #13 |
If u weigh over 165 u will be better off running a 16t front sprocket. If less than 165 I would run a 17t. It's really personal preference. I'm 160 and have tried both and I liked the 17t better, higher top top speed at less rpm.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
