09-29-2019, 04:40 PM | #1 |
How to jet the carb ?
When i open throttle while riding, bike starts to jerk, even opening it as little as 1/4 turn.
Does NOT bog in neutral. My fuel/air mix screw is at 2-1/2 turns out and needle is NOT shimmed. Bike idles normal, does NOT jerk when opening throttle while in neutral, only when riding. I obviously need to jet the carb but i need to know 2 things please: What type of jets i need to order What jets size i need at the elevation 0 to 250 feet at most. Judging by the THEORETICAL concept of carburetors show below, problem starts at the needle. Thank you in advance. |
09-29-2019, 10:16 PM | #2 |
Sounds like clutch is slipping. I had that. Does the oil look like mud? Mine does with steaks in it..Search on crank case ventilation oil water separator if your bike has that
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
