11-14-2019, 11:03 AM | #1 |
Which Bike? Looking for suggestions
Hi Gurus,
I've been away from offroad riding for some time (except mountain bike) and am looking to get back into it. I really like the Honday 250 rally. But don't want to spend that much money on what would likely be my re-entry point before going bigger. So looking for a bike with similar specs (minus HP on the 250s). I'm considering the: SSR XF250 (looks like it has everything needed to get started) Brozz 250 (i'm concerned it might be a little small) Orion RXB-250L (looks a little short on accessories) Hawk DLX 250 (concerned with wheel base, and it seems the seat height specs vary from site to site)? And now the outlier due to price, but it looks compelling GPX FSE 450R (still pe-order ?) But a longer term option I'm 52 years old, 6', 195lbs. Thanks for all the help!! -Jim |
11-14-2019, 11:10 AM | #2 |
Welcome aboard! If your looking for more off-road capability I would stick with the Orion RXB-250L. On and off road I would go with the SSR XF250. Nothing wrong with the Hawk or Brozz but the above have a much better suspension for off road.
11-14-2019, 02:36 PM | #3 |
Thanks
Thanks, Jerry,
And I appreciate your videos, I've watched them all and they are one of the reasons the hawk made the list (motocheez also). Can you tell me what the actual seat height is of your bike? I see it at 34" on some sites, 36" on others? Also, would you mind sharing your height and weight? Just curious to see if you feel the bike is right-sized for you. Jim |
11-14-2019, 02:39 PM | #4 | |
11-14-2019, 02:40 PM | #5 |
What it lacks in farkles it makes up for with hardware. As Jerry said, it has the best suspension of all the bikes you named. It has more travel and full adjustability behind it and some billet aluminum hardware as well.
The funny thing is, I know exactly what bike you are looking for, because I think it is the same bike many of us want. We want the hardware of the RXB and GPX bikes with the bigger fuel tank and more road bike friendly seating/equipment of the cheaper bikes. The Hawk DLX/TT250/Brozz look like the bike I just described, but they aren't, not even close. They have the cheaper upside down forks and cheaper steel swing arms with direct mount shocks, both with fairly limited travel (6-7 inches max) when compared to a proper off road bikes 8+"
11-14-2019, 04:55 PM | #6 |
I really like my Hawk but If the Orion RXB-250L would of been available 3 rears ago that would of been the bike I would of bought. Much more suited for off road.
11-15-2019, 10:51 AM | #7 |
More thanks
Excellent commentary everyone, keep it coming.
11-15-2019, 10:56 AM | #8 |
I think the Orion RXB-250L will be the best bang for the buck. Upgrades along are worth it.
11-15-2019, 07:16 PM | #9 |
I too think the Orion RXB is a top choice. But since I don't have any real experience with any of the bikes you listed except for one, I will give you what I think about the Brozz.
You stated your fear that the bike will be too small. I am 6'1" tall and can't flat foot the bike so I don't think that will be an issue at all. The Brozz is a very solid bike for $1750. When I first got my bike together and went for the first ride I didn't go too far in fear that it would leave me stranded. Well at over 3000 miles now I have no fear of leaving home and returning five or six hours later. I fully trust the reliability of the bike. I haven't had any issues with it of a break down or parts falling off or anything of the sorts. It's a real good bike for the money. But you stated that you want to get back into off road riding and there is probably some better suited bikes out there for hard core dirt riding. But if you want to hit the trails and do some woods riding and nothing extreme I think the Brozz would shine there also. One thing to consider is a dual sport is not great in both of the dual sports in most cases, one will be better suited for road commuting and another maybe better in the dirt. So whatever works best for you is what is best. Another thing to consider at 52 years young is comfort. I think the seat on the Brozz is probably one of the best stock OEM seats I have sat on. I can ride for hours with little problems on this seat. The riding position is very good as well, as I'm sure most of these dual sport bikes are. The bike feels very planted on the road and gives you confidence that it will be a safe ride. The Brozz also has a pretty good size gas tank and at almost 70mpg I can usually go almost 200 miles between fill ups. As good as the RXB is and I think it is very much worth the money for all that you get. For me at 59 years young the seat and the small gas tank is a deal breaker. But then again I mostly use my bike for commuting. The one down side to the Brozz is the CG 15hp engine. With a few mods, and mods are relatively cheap, you can make it run with a little more pep in it's step though. Whatever you decide I wish you well and Welcome!
11-16-2019, 04:53 AM | #10 | |
Give me a Hawk DLX with THAT combination (and a higher mounted rear master cylinder and aluminum rims) for no more than $2500 (and the Orion proves it could be done!) and I would trade my current Hawk out in a heart beat.
11-17-2019, 09:09 AM | #11 |
Really good stuff fellas
Herbie,
Thanks for your comments and you have gotten me thinking about the Brozz (and my original post). I gave this a lot of thought last night (not to mention spent some time on a DRZ400 yesterday). My original post does lead one to think I'm primarily interested in off-roading. In reality, it's a mix of on/off-road. Use the roads (I do enjoy this also) to get to the trails. Thus an Enduro/Rally bike is ideal for me. I wish Ducati would make a smaller desert sled (that would be a no brainer), I also wish the SWM was more affordable (alas, it will never be). So instead of targeting the perfect affordable bike, I think we have to look for a base platform that allows us to get there. So, maybe the Brozz is it? The upright riding position, nice sized gas tank and affordable. Specs that are condcive on-road and in the trails (let's face it, I'm not the rider I used to be). Apologies if I'm all over the place. Jim |
11-17-2019, 02:02 PM | #12 |
Last week I followed a group ride in my Subaru out in the desert wilderness outside of the Phoenix area (it is the thread about the Wickenburg ride in the Riding section).
There was member Musictrek on his Brozz 250, member Emerikol's friend on his Hawk 250, and member Alex_in_AZ on his Tao TBR7. Most of the ride was on the sand, but all three Chinese bikes (Emerikol himself was on his Suzuki DRZ650 while he made his friend who flew in from Georgia get the Chinabike experience on his Hawk, lol) did well. All 4 riders rode to the starting point, and once we all got to Wickenburg, all four riders rode back towards Phoenix on highways. All four bikes were fine...yes Alex on the Tao TBR7 had some problems; one was a flat tire thanks to a LARGE desert shrubbery's thorn, and the other was starting problems which he easily solved later on with a new CDI unit. The point is, any Chinese bike can be a great starting-off bike. I was impressed with each one, INCLUDING the TBR7 (I had a feeling the issues were an easy fix), because each one for me could be used as a daily commuter (33 miles round trip a day), and weekend explorer. That being said, if you are considering a bike to beat on and for longevity and are willing to pay extra dollars for, but under the price of a 'brand' name, go for the GPX. Here is a good review of a 250 version:
11-19-2019, 08:54 PM | #14 | |
The GPX FSE250R is the better bike. It has the 6-speed water-cooled EFI engine. Top notch suspension & components. Ask if they are still on sale. Here's a great thread about them: https://thumpertalk.com/forums/topic...sembly-thread/ |
12-02-2019, 11:27 AM | #15 |
Thanks all,
GPX FSE 250E is on it's way. I went with this bike to use short term, then gift to one of my boys. To be followed by a 450R for me (assuming all goes well) Jim
-Jim www.varka.us 03 HD Sportster 84 Honda Magna Trek Mntn bike GPX FSE 250E coming soon |
