Boom lil duc/vader has an extremely hard clutch pull
I am the somewhat proud owner of a boom lil duc, which is basically a vader 125, the clutch lever is very hard to pull, ive been making do for the last 2 months but it gets tiring when im in stop and go traffic. Its been like this since it arrived and ive tried adjusting it but i am not a very good adjuster so i always end up putting it back where i started since i cant find any other setting that works.
If you have already tried using a good quality cable lube ( the Chinese are infamous for using little to no lubricants, or lubricants with extremely questionable worth ) I would suggest tracing the cable from the grip all the way down to the point it connects at the engine case, it is not uncommon at all for the cable to be pinched or binding due to poor routing / placement of the cables during the initial factory assembly stages.
This is after all a 125cc engine and the clutch pull should by no means be unmanageable so lube it if you haven't and then check the cable routing ,and let us know what you find out.
Get silicone grease spray. I've revived almost stuck car window elevator mechanisms with that stuff, extremely slippery inside cables as there is (or at least ought to be) a nylon/teflon sheath inside the hard outer casing for the cable to slide against. Silicone grease makes it slide with almost zero friction.
2004 Longjia Grido 50 scooter 1999 Cagiva Mito 125 Evo, Yamaha XV125 engine, Ducati SS fairings, getting turboed 1993 Yamaha GTS 1000 Ex:Bashan BS200-S7 `07 Streetfighter-quad |
For all its worth, call Pete at Kronik Racing in Simi Valley, California. He is the Vader guru and probably is the dealer that sells the most of these; he has a brick and mortar shop and stocks parts, and is always at Baodiao's US headquarters in So. Cal. which means parts are NOT an issue. He is always willing to help out. 805-630-7223 www.kronikracing.com
