02-18-2020, 01:11 PM | #1 |
Is the TBR7 odometer wildly inaccurate?
Hey folks,
I recently received my TBR7 and have ridden it for maybe 20 minutes total around the neighborhood. However my odometer is now reading 39 miles up from 4 miles when I took it out of the box. So my question is did I do something wrong or is the stock odometer really off by that much? |
02-18-2020, 01:50 PM | #2 |
It's not uncommon for the readout on these Chinese Bikes to reflect " MPH" as far as speedometer , but it records "KH" or " kilometers" traveled rather than miles traveled in the odometer field, which is most likely why it shows a high reading .
My Vader was the same way out of the box .
02-18-2020, 02:02 PM | #3 |
That would still be like 24 miles which there's no way I ever did by going around the block a few times.
02-18-2020, 02:36 PM | #4 |
I don't think any of the stock speedometers are accurate. I know the one that came on my Hawk was about 6-7 mph off and odometer wasn't even close to miles or kilometers. lol Replace it with an after market speedometer that you can calibrate. My new bike is about 9-10 mph off.
02-18-2020, 08:10 PM | #5 |
Yes the TBR7 speedometer is off. I got a phone ap that uses GPS for speed and distance and found that the speedometer is really optimistic.
02-19-2020, 03:08 PM | #6 |
go with this one from Nzbrakelathes....you can set the calibration to your front tire circumference to be 100% accurate.
https://www.ebay.com/itm/Tao-Tao-TBR...MAAOSwv4tdbyr-
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 Last edited by cycleway4; 02-19-2020 at 04:09 PM. |
02-20-2020, 09:38 PM | #7 |
More info here etc.
2 options more color more of everything lol http://www.chinariders.net/showthread.php?t=24345 |
02-21-2020, 09:48 AM | #8 |
I tested my Brozz last night and saw a 5 mph + difference than the GPS.
02-21-2020, 09:53 AM | #9 |
For the digital Speedometers you can install a SpeedoDRD to calibrate the speedometer. I lucked out when I went to place my order a 10% off coupon popped up and got mine for $63. My speedometer on my Venom X22R is about 8.5% off. https://www.ebay.com/itm/SpeedoDRD-U...72.m2749.l2649
02-21-2020, 11:26 AM | #10 | |
02-22-2020, 02:40 AM | #11 | |
Easy fix tho.... |
03-03-2020, 07:52 PM | #12 |
I have a spare Bross style fit the TBR7 in Virginia, the Tacho ATM won't work for the Blue Eagle he has BUT 100% confirmed fine for the TBR7 etc.
$60 plus shipping from VA if someone wants a deal n faster shipping from within the USA. |
Tags |
inaccurate, miles, odometer, tao, tbr7 |
