03-02-2020, 04:57 PM | #1 |
Alpha Sports LG50 No Crank...(Video)
Please see video below. It's a 2 stroke and I'm stumped. Thanks so much fellas!
03-02-2020, 06:37 PM | #2 |
Wanted to add additional info. Video below. Thanks again.
03-02-2020, 09:05 PM | #3 |
Update#2.... The reed valves look to be in good shape. They are sitting nice and tight and level. Please see video below... After checking this, I'm at even more of a loss. Help pllleaaase.
03-05-2020, 05:53 PM | #4 |
Update: well I did a compression test and it gave me 60psi. :(
03-05-2020, 08:06 PM | #5 |
Before you get discouraged with that result, what compression gauge are you using? How long is the hose + adapters. The longer the hose the more volume you will have, thus resulting in a lower pressure reading. Also depend where the check valve is located in your setup. Granted, that’s pretty low, I encountered a similar issue with a jet ski. Using a cheap gauge and 1 foot extension with adapters, resulted in 30 psi lower than actual...
03-06-2020, 07:56 AM | #6 |
Also when checking compression make sure the throttle is wide open.
03-07-2020, 05:45 PM | #7 |
Still getting the same compression reading of 60psi. Anyone know how tough it is to repair?
