Old 04-03-2020, 12:27 PM   #1
HighMountianHawk   HighMountianHawk is offline
2020 Brozz 250 vs. 2018 Hawk Rear Shock
Does anyone know if the rear shock from a 2018 hawk has more suspension travel then the 2020 Brozz Recon rear shock and can the rear shocks be switched? Thank you
Old 04-03-2020, 12:47 PM   #2
Travel is likely very similar. The real difference will likely be in length due to the Brozz swing arm having a higher mount point on the swing arm. Comparing the two shock lengths would be a good idea. The Hawk is 320mm center to center. AFAIK nobody has posted the stock Brozz shock length.
