Old 04-06-2020, 09:11 PM   #1
pillihp   pillihp is offline
Rhino 250 trouble starting
So I finished riding today and hosed down the bike. After I hoard all the mud off of it I tried starting it and it struggled to start. Once I got it started the throttle wouldn’t respond at first. After a minute or two of running it was running normally and I was able to drive it into the shed. Any idea what would cause the engine to start, sputter, be nine responsive to throttle, then die?
Old 04-07-2020, 07:53 AM   #2
Mudflap   Mudflap is offline
First thing I would suspect is water in the air filter.
Old 04-07-2020, 11:04 AM   #3
Rob G   Rob G is offline
Rob G's Avatar
I second what Mudflap said. Second the carburetor has a vent on it, if water gets in there it will add water to the fuel in the float bowl. Also, electrical things don't particularly like water either, such as water puddled around the spark plug or seeping into the joint between the spark plug wire and the coil, or under the spark plug boot, the stator, or.... this could be a long list. When washing it down, I would avoid (as much as possible) things like the carb, air filter, and electrical components. Things that do get wet, blow them with an air blower from a compressor if you can.
"If money is your hope for independence, you'll never have it. The only real security that a man will have in this world is a reserve of knowledge, experience, and ability." Henry Ford.
2018 Tao Bull 200 red
2018 Tao Bull 200 green
2018 Tao New T-Force graffiti
2018 Tao New T-Force blue
Old 04-08-2020, 08:45 PM   #4
It’s definitely electrical. Hosed it down tonight and it did the same thing. After I got it going I parked it, left it in reverse with the high beams on and the reverse indicator and the headlights were dimly glowing with the key off.
I’m going to start it up tomorrow and wet it down a little at a time until I find the culprit.
Old 04-10-2020, 02:15 AM   #5
Rob G's Avatar
Round about '96 I worked on a pickup in the shop that had suffered an engine fire before. The owner put a new harness in it and everytime it rained he had all sorts of gremlins. Looking at the schematic we traced all the components that acted up. Then we took a water hose on a trickle and started to soak everything in each one of those circuits until we duplicated the problem. Turned out to be a connector, when it got wet it would short internally. Since ATVs are so small, perhaps a similar process can be used but with a squirt bottle.
Old 04-10-2020, 02:35 PM   #6
That’s my plan. The weather hasn’t cooperated though
Old 04-10-2020, 04:13 PM   #7
Rob G's Avatar
Always seems to be the way of it. Curious to hear what you find.
Old 04-12-2020, 06:51 PM   #8
Got around to troubleshooting this. It’s the coil. When it gets soaked it stalls and won’t run until it dries out
Old 04-13-2020, 01:19 AM   #9
Rob G's Avatar
That's some good work. Thanks for the update, now I know what to keep and eye out for and, should something act up in wet conditions, where to start.
