04-13-2020, 01:54 PM | #1 |
TBR7 headlight
So far, I'm loving this bike except for one thing. The headlight on it is craptastic. I ordered an LED bulb from ebay, but it isn't any better. The reflector for the headlight doesn't seem to focus the LED well at all. Has anyone had any success replacing the bulb or even the entire headlight assembly to something that is improved over factory?
04-13-2020, 02:10 PM | #2 |
Same for the storm, led helped but still sucks. A lot of people put led pod lights on the front to help.
04-13-2020, 03:17 PM | #3 |
craptastic is being generous its horrible.... i am putting some LEDS on mine.... not sure where to tap power from though.....
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
04-13-2020, 03:35 PM | #4 |
run a wire from the battery to a relay, have the light switch trigger the relay. Won't cost much and you wont have to worry about smoking the stock harness.
04-13-2020, 08:06 PM | #5 |
China bikes even the bigger have crap lights - my RX3 has an LED headlight n still crap as most bikes or all bikes do.
Extra lights on the side with relay I would suggest RELAY so you don't burn the ign switch or light switch etc as stated |
04-14-2020, 03:23 PM | #6 |
a relay for sure..... i was planning on mounting them to the reflector mount on the fork......anyone do this already? i think jerryhawk may have....
04-14-2020, 03:41 PM | #7 | |
Power for spots
If you replace the main headlight with an LED, then you "save" enough Amps to not draw too much when adding the spots (which don't really draw much either). Check out spots at SuperBrightLEDs.com The first one are the ones I got. The second ones are twice the $, but I think likely better. I got mine at 60 degree angle, the more expensive ones have more options 10, 30, 60, 120. https://www.superbrightleds.com/more...rk-light/1671/ https://www.superbrightleds.com/more...0-lumens/1699/
CSC TT250 Orion RXB 150XL |
