Old 04-29-2020, 12:45 PM   #1
Rich10   Rich10 is offline
TaoTao kart upgrade
Hello All,
I bought a TaoTao gokart with a gk110 engine. The engine is really badly seized. I was wondering if you guys know of a drop-in engine that's bigger or that's a 4-speed. The gk110 ran well and had ok speed, but it always felt like it had a lot of top end speed left and could use another gear.
If I could upgrade to a 125 or 150+ that would be great!
Any suggestions?
Thanks
Old 04-29-2020, 01:49 PM   #2
wheelbender6's Avatar
Better to post some pics of the Kart and drive train, as these model numbers change all the time.
Old 04-29-2020, 03:01 PM   #3
Originally Posted by wheelbender6 View Post
Better to post some pics or the Kart and drive train, as these model numbers change all the time.
Yes, sir!
Old 04-30-2020, 04:09 PM   #4
duck9191   duck9191 is offline
that looks to be the common pit bike/ mini quad motor. You have tons of options, full manual, semi manual, full auto like its got and ones with reverse. if you want to spend a good bit you should be able to get a 190 in there.
This is one of the site vendors, they have some options.
https://www.vmcchineseparts.com/coll...mplete-engines
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 05-06-2020, 11:07 AM   #5
They're all sold out.
Old 05-07-2020, 11:52 AM   #6
PhildoScaggins   PhildoScaggins is offline
here is a 125cc auto w/ reverse
https://www.taotaopartsdirect.com/collections/engines/products/125cc-auto-w-reverse-engine
or here
not great power, but a very simple swap.
Old 05-10-2020, 01:06 PM   #7
Ina Ditch   Ina Ditch is offline
Ina Ditch's Avatar
https://www.gopowersports.com/
Try these folks
Old 05-25-2020, 08:13 PM   #8
So I bought and received the 125cc engine.
The wiring harness on the cart has a 5 wire and a 3 wire. The harness on the new engine is a 5 wire and 4 wire.
Do you guys know where I can get an adapter?
Old 08-04-2020, 10:19 AM   #9
Hey dudes,
So I've been a little busy, but I got this thing assembled.
Here's the situation-
There is spark.
Won't fire with ether.
Fuel is getting into the carb.
Won't fire up.
Any recommendations?
Old 08-04-2020, 02:37 PM   #10
Hey dudes,
There is spark.
Won't fire up.
Check valves. Sometimes out of the crate these can have valves that are 100% tight.
Old 08-04-2020, 04:01 PM   #11
Yep check the valves. Timing could be off too, did you use the stuff that came with the new motor?
Old 08-04-2020, 04:06 PM   #12
Yes, used all the new stuff with the motor.
I tried a brand new carb, as well.
