Hi all, I got my 42 tooth rear today, put it on (weird set up back there with the bolts) anyway, with the jets, and 17 tooth front,bike really came alive! Top speed in gears is dramatically extended. The torque band is more spread out through the revs it seems, with what seems to be MORE punch. First gear is still low enough for creeping along. I got 40mph in third gear😁. Bike is improving with the mods above and breaking in very well. I'm gonna leave it like this,(power train anyways). Next is nobbies and improved lighting.
Safe riding all. Christopher |
Welcome to the reason us Hawk guys like the 17/45 on our bikes. Glad you like it
Chris - may I ask if you share a link on where you purchased the 42 sprocket.
And maybe a pic of the weird set up you mentioned. Definitely want to do the same for my bike given I ride 99% street. |
#4 | ||
![]() Did you do the Jet/Exhaust yet and the NGK iridium? that's another nice step up.... ![]()
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
Hi all, king, stogie I haven't done an exhaust, or nobbies yet, only what I have mentioned. Can't take a pic of the rear sprocket setup on a tbr7, it's already back together it is not a (just bolt the sprocket to the hub). It goes like this... break the nuts loose while the bike is on the ground, in gear, wheel still attached tight! Those nuts are on very tight.
I used a 3.foot pipe to get them loose! REMEMBER, CHEEP CHINESE SOFT NUTS! Don't strip them. Then remove wheel assembly, the sprocket is held on to the wheel by a strong retaining clip. Use snap ring pliers! The sprocket will now come off the wheel. The studs that the sprocket goes on just SITS in the 4 holes in the hub, the sprocket bolts to the studs WITH the FLAT side facing out, the side of the sprocket that has a channel groove in it is to accept the SHOULDER of the pins to keep it from turning when you tightened the nuts to fasten the sprocket to the pins. The ONLY thing that actually hold the sprocket to the hub is the retaining clip. MOTOCHEEZE, and others have utube vid on doing it. Don't damage the retaining clip, and make sure it is ALL the way in the groove in the hub that it fits into. Otherwise it will fail, sprocket,chain will come off......imagine that at 60 mph! Safe riding Christopher |
Ps. I got both my sprockets on Amazon.JTsprockets go to motocheez.com use his link he has under parts for tbr7- HAWK 250. (Same wheel) I don't have the parts number handy ill try to find the stuff my parts came in for numbers, I'm using the NGKDR8ea plug they
Sent me. Should we riders be using a resistor plug with a resistor cap? Christopher Sun came out on long island today, I'm going for a ride! |
Sweet..thanks buddy!
