05-12-2020, 11:52 AM | #1 |
TBR7 and Knobby Tires
Still waiting for the machine to get here - but looking at some more aggressive tires for around the property. Anybody have any luck find knobby or otherwise more aggressive tires for this?
90/90-19 Front 11/90-17 Rear Can't find much online that would work. But I'm considering changing out the entire front/rear wheels if I can find tires that would work. |
05-12-2020, 12:21 PM | #2 |
Thr Brozz recon tires will fit the TBR7 wheels. If you are willing to buy a new front rim I'd suggest the hawk rim, the speedometer will actually read correct with the 21" wheel swap. The rear tire can be as wide as 130 so 110 is not absolutely required.
05-12-2020, 12:40 PM | #3 |
I'd buy a Kenda Trakmaster II for the rear and try to find out what company is making the front tire for the Brozz Recon.
05-12-2020, 06:44 PM | #4 |
Hi all. I have a 2020 tbr7. I'm looking for knobby tires to. Can't seem to find the ones that are the stock size. Front trakmaster II come close, but I'm worried about the rear they all seem to be bigger. The swing arm has SOME room but I concerned about the muffler above, that looks like trouble.
Some one said they have full knobby on their bike here? If so what kind,sizes? Thanks in advance Christopher |
