05-14-2020, 04:19 PM | #1 |
Think I know the answer....BUT
I probably know the answer to this. But, there is suppose to be a bolt head there right?
Also, does the TT250 bolt fit on this? Thanks
Hawk 250 Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
05-14-2020, 04:36 PM | #2 |
The tt250 unit does work, but its not a bolt. It is a shaft with two threaded ends. If you order it make sure to order two washers and two nuts for it as well.
05-14-2020, 06:24 PM | #3 |
Alright. thanks Dan. I appreciate it.
