Hawk 19" front whreel
Hello, The Hawk normally comes with a 21 inch front wheel but my friend wants a 19 inch front wheel that will fit the Hawk. Can anybody post a link to a 19 inch front wheel that would fit? his hawk has the standard forks. Also can anybody tell me the shaft size, and the brake disc size in case I find one on eBay. thank you.
Easiest way to get a 19 inch front wheel would be to order an old style Brozz front wheel. They had the same forks as the Hawk.
Here you can see it listed for $45 for the "Standard Grey Forks" which is what our bikes and the old brozz had. https://shop.brozz250.com/eshopprod_...l_Assembly.htm The Hawk's brake rotor should swap right over as well. The only real unknown would be the right side wheel spacer. I would order that to be safe, but it is likely the same size. However, it's only 5 bucks (Scroll down to part 9S). Brake disc is 265mm, same brake rotor as the old GY200 bikes. I do believe the Brozz rotor is the same dimension, just a "wave" style, but I have no way to confirm it. If you contact Jeffery (ID here is PeaceSportsAtlanta) he might be able to confirm it with you
thank you, I appreciate the information
