05-17-2020, 07:46 AM | #1 |
Rhino rear sprocket
I'm wanting a 40-45 tooth sprocket for my rhino in the rear is ther any other place other than whygostock to get it? 80 bucks is a little much imo for just the sprocket plus I'll need a new chain I've searched but cant find any other thanks in advance!
05-17-2020, 08:40 AM | #2 |
One option is to switch to a 428 setup using a JTF 259.12 front sprocket, a stock 40 tooth rear from a Taotao ATA250D, and a 428 118 link chain. This gives you a 3.33/1 ratio and inexpensive sreel sprockets that last a long time as opposed to aluminum.
05-17-2020, 10:31 AM | #3 |
Does it pull pretty good that way? And any other modifications I'll have to do like grinding the retainer clip or what would I need etc
05-17-2020, 10:57 AM | #4 |
Huge improvement in pulling power over stock. 30 to 35 mph is top long distance cruising speed but it'll do 40 max. I don't use the retainer plate, instead i make a spacer by removing the teeth from an old sprocket and put it behind the new sprocket. The splines prevent the spacer from contacting the seal. A couple standard snap rings fit inro the retainer groove to hold things in place.
