Old 06-10-2020, 11:30 AM   #1
Yeg.chrisc   Yeg.chrisc is offline
Crf230f cylinder in an X31?
I'm having a hell of a time finding top end parts for my X31.
ZA169FMM, more like a 65mm bore with 15mm pin.
It looks like the valves are the same dimensions as the crf230, so I ordered seals from Honda already.
Old 06-10-2020, 01:50 PM   #2
franque   franque is offline
Yep, it should work. You'd be the first on here to do it though, so make sure that you document it!
Old 06-10-2020, 02:07 PM   #3
I recently installed the CRF230F Wiseco 11:1 piston on my X22R 250. It's a 65.5mm bore with 15mm pin.
2004 Honda ST 1300
Old 06-10-2020, 02:19 PM   #4
The CRF230F Big Bore kits and cams will also work on these engines. https://www.ebay.com/itm/Athena-67mm...2228ab027919bc
2004 Honda ST 1300
Old 06-11-2020, 10:24 AM   #5
I see a bunch of pistons sold as 65.5mm of, do you guys think it means they are actually 65.5mm of or they are meant to for a 65.5mm cylinder??
Old 06-11-2020, 10:30 AM   #6
They are meant for a 65.5mm bore. I don't remember the exact measurement but the piston is slightly smaller.
2004 Honda ST 1300
Old 06-11-2020, 12:47 PM   #7
Mine is like 64.98mm.
Old 06-11-2020, 01:28 PM   #8
Stock piston on a 65.5mm cylinder would be around 65.49-65.47mm. Service limit is 56.40mm.
Did you measure the bore of the cylinder?
2004 Honda ST 1300
Old 06-11-2020, 04:51 PM   #9
Yea the cylinder is 65.5 top, bottom and middle.
Old 06-11-2020, 04:54 PM   #10
So yeah that piston is worn out at 64.98mm.
2004 Honda ST 1300
Old 06-11-2020, 09:24 PM   #11
humanbeing's Avatar
From CRF230F shop manual:
Measure at the gauge point w/ correct tool & not as these http://www.chinapartsdepot.com/shopp...exd.asp?id=771 clowns as possible
The average Chinese Joe will just put another 67 BBK https://item.taobao.com/item.htm?id=617131505511 when worn.
Anway the standard 65.5 chonda nowadays is using [0.8/0.8/2.8]. Why such 2.8 oil rings cuz there's history reason https://motorcycle.sh.cn/thread-17320800-1-1.html (Change to destop mode if via from mobile device) Suzuki F10A (& copycats) 2.8 really works unlike the bike specfic thin rings they failed to copy ...
Old 06-11-2020, 09:52 PM   #12
Yea, 0.52mm clearance is double what it needs to be.
I have a new piston coming. Bore seems alright. Once I get the new valve seals and piston installed and the bike running, I'm going to order a crf230 big bore kit whick I think is about 67mm, and they come with a domed piston. But I just want to get back riding asap.
Old 06-12-2020, 07:40 AM   #13
Check the cylinder for roundness. If the piston is worn that much cylinder could be worn too. Also you want to hone the cylinder so the the new rings will seat.
Here's a link to the CRF230F shop manual. https://www.google.com/url?q=https:/...91965565636000
2004 Honda ST 1300
Old 06-12-2020, 10:00 AM   #14
How old is this bike? A piston that worn out would likely not run in the engine, I've never seen one wear out a whole half mm. The piston/cylinder would look pretty gnarly if it was that much worn out.
Old 06-12-2020, 10:05 AM   #15
I was thinking the same thing. A new cylinder and piston would be the way to go. Might as well do the BBK.
2004 Honda ST 1300
