Old 06-25-2020, 03:48 AM   #1
Larky   Larky is offline
Tbr7 overcharging battery
As the title states, my tbr7 is over charging the battery. I replaced the voltage regulator/ rectifier and it’s still over charging. I got the regulator off amazon and was happy that it literally just plugged right in. It’s putting 16v to the battery and climbing. Does anyone know what the typical stator a/c output is? I have also verified the regulator/rectifier and battery grounds and they are good. Any other thoughts on this are graciously accepted
Old 06-25-2020, 06:35 AM   #2
franque   franque is offline
What kind of regulator did you put on it? How did you verify that it was good?
Old 06-25-2020, 07:49 AM   #3
I didn’t verify if it was good. I assumed it was good because it was brand new purchased from amazon, still in the original unopened package. I know, I know, that’s no guarantee, but that’s what I have to go on.
Old 06-25-2020, 09:24 AM   #4
f15sim   f15sim is offline
f15sim's Avatar
What's the expected output at a specific RPM?
g.
Proud owner of 80-0007.
https://www.f15sim.com - The only one of its kind.
Old 06-25-2020, 11:32 AM   #5
g.
From my research online, the voltage should not exceed 14.8 at any rpm. I’ve had from 16v and up to 20v measured at the battery.
Old 06-25-2020, 11:35 AM   #6
You may have gotten a faulty regulator.
2004 Honda ST 1300
Old 06-25-2020, 11:55 AM   #7
Have you tested the volt meter on another charging system, so that you know it's reading accurately?
Old 06-25-2020, 12:12 PM   #8
Good point. I haven’t. But what started this was my original battery went bad. So I replaced it and started the troubleshooting process. But still a good point. I will check that tonight when I get home.
