Old 06-29-2020, 05:49 PM   #1
vtwinaddicted   vtwinaddicted is offline
Doh! Brozz 250 shifter
When ordering a new shift lever for my brozz, should I order one for a crf230??, or is there a better option?
Old 06-29-2020, 06:55 PM   #2
Spins   Spins is offline
Spins's Avatar
I ordered two different options from Amazon for a XR 250. One cheap and a IMS $$. They both didn’t stick out far enough for my boot to catch. I had to twist my foot inward in order to shift . Returned both. I stayed with the stock cheap one.
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 06-29-2020, 09:06 PM   #3
markerdown   markerdown is offline
markerdown's Avatar
I bought a bikemaster off amazon for mine. I think the callout fit ws 230 400 600
73 Plymouth cuda 340
73 Kaw Z1 900
18 Kaw Z900RS
20 Brozz 250 Recon
21 Honda Africa Twin
21 Ice Bear Champion 125
22 GPX FSE 450R
Old 06-29-2020, 10:11 PM   #4
gwowzer   gwowzer is offline
I got an IMS Flightline off Amazon. I like it. Out of the way more than the stock shifter.
https://www.amazon.com/gp/aw/d/B000U...b_b_asin_title
Old 06-29-2020, 10:16 PM   #5
Oh and now that I think about it, if you do order that one, fit is good and everything but I do believe I took a trip to the hardware store to get a slightly shorter bolt for mounting. Clearance is tight to start the threads on the mount/clamp bolt. Easy enough though 85 cents and a reason to ride.
Old 07-13-2020, 09:22 PM   #6
Ina Ditch   Ina Ditch is offline
Ina Ditch's Avatar
did the splines fit right? all the talk has been crf230 is the cross fit for the brozz bikes and this wont fit the 230 according to the cross reference.
I am ready for an upgrade after having to work the wrinkles out of the stock one 2 or 3 times
Old 07-13-2020, 10:19 PM   #7
Spins's Avatar
Shifter
This will fit. Great quality but it doesn’t stick out very far. My boot would barely grab it. I ended up returning it as I had to make a mental effort to twist but foot inward to shift.
Model # IMS 312223
IMS 312223 Flightline Folding Shift Lever https://www.amazon.com/dp/B000UKO37Q..._HCrdFbW8H3DCE
File Type: jpg CE35AA59-030F-4421-A76A-31E7B9C4BBDB.jpg (7.6 KB, 1135 views)
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 07-13-2020, 10:38 PM   #8
Deckard_Cain   Deckard_Cain is offline
Model # IMS 312223
This is the one input on my Hawk.. I used a button head screw I had left over from the front sprocket upgrade on my kids taotao atv.
Splines line up perfectly and it sticks out just far enough. The folding end is nice, and I think it'll take exponentially more force to bend the entire lever compared to stock.
I kept the stock one in my garage drawer as a spare of course.
But I do recommend the IMS flightline, it's a good lever.
Old 07-15-2020, 01:06 AM   #9
Ina Ditch's Avatar
Thanks fellas,
Spins, I am going to give it a try, I have a lot of metal working tools and should be able to add offset pretty easily but I really appreciate the heads up because now I know not to expect it to be perfect out of the gate.
Old 07-15-2020, 07:04 AM   #10
Spins's Avatar
Thanks fellas,
It’s a quality made product. I just wish the folding end was twice as long. Guys told me to mod it. $30 for a shifter , I felt I shouldn’t have too.
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 07-15-2020, 09:28 PM   #11
Ina Ditch's Avatar
I agree but kinda expect to have to with a knock off and just looking at it I am hoping it will be a pretty simple tweak.
