Old 06-29-2020, 08:25 PM   #1
Rastar   Rastar is offline
Rhino air filter replacement
My TT Rhino came with a tube air filter? What would be a recommended replacement type??
Thanks
Old 07-01-2020, 11:56 PM   #2
Vwchisme   Vwchisme is offline
I ended putting this on. After trail & error, i mounted the end where you see the filter to the carb side instead. So it would sit inside the body for better protection.i can take pic of the final set up if you like.
[IMG]Taotao 2007 carb upgrade by ntrodriguez, on Flickr[/IMG]
Old 07-02-2020, 05:31 AM   #3
Mudflap   Mudflap is offline
I use Chinese copies of a foam UniFilter form Ebay. Less than $5 shipped. 38mm opening, angled.
Old 07-02-2020, 12:23 PM   #4
Same here. The stock Rhino filter is nothing more than shipping garbage to keep rats out of the carb in the container. ;-)
Old 09-02-2020, 01:17 PM   #5
machineguneddie   machineguneddie is offline
machineguneddie's Avatar
I use a K&N type filter on mine. Cheap enough on ebay.
