Orion RXB 150 tuning, please help so close. Bike porn added
Hi, I am new here. first post. not sure if this is the right category.
Last week i got my RXB 150 xl street legal bike, i need help tuning. I am almost there, real close but kinda stuck. Heres the run down. Bike shipped with no clutch disengagment, barely had enough adjustment available to get it to work. Knock off mikuni was crap, bike barely ran, sputtered, backfired, made a quick sucking noise and died. Yesterday, i installed the following nibbi 26mm carb new racing cdi K&N filter and bought jets. I am at 300' in washington state. sometimes humid, more often comfortable. I started with 115/38 jets needle 2nd from bottom........... bike actually idled but still died on throttle release. tried 120/42 needle in 2nd from top... too rich wet plug, but started easier and idled better tried 115/42 needle in middle.... a little dark on plug but not wet and bike started the best, idled the best, and almost threw me off in first gear, i wasnt expecting the extremely sensitive response. however, a tad sluggish in second, a little bog under way that you dont notice on sitting still. whats my next move?????? im so close not sure which way to go thanks!!!!! Last edited by nritchie30; 07-09-2020 at 07:41 PM. |
Hello! Where in the throttle does it bog? Is it from quarter throttle all the way through wide open? Or is it just between quarter and three quarters?
My understanding of carbs, breaks the jets down into contributors to the overall flow. You may need to just drop down on the jet needle or needle jet if its between. Or the main if its wide open throttle. Check out the image toward the top of this page: https://www.howtomotorcyclerepair.co...ircuit-mikuni/ Hope it helps. |
#3 | |
Idle, pilot screw, pilot jet, needle clip, main
You should not change more than one thing at a time. I learned from several tuning manuals the following order for tuning: Idle, pilot screw (between 1 to 2 1/2 turns), pilot jet (if screw is less than 1 or greater than 2 1/2), needle clip (down richer, up leaner), LAST main. Here are a few of them...put them all together and the whole process begins to make sense: http://www.vintagebikebuilder.com/mi...ing-guide.html http://www.ccwthariders.com/uploads/...ing_manual.pdf http://www.iwt.com.au/mikunicarb.htm http://www.takegawa.co.jp/files/03-05-0031.pdf
CSC TT250 Orion RXB 150XL |
I am currently helping a gentleman tune his TBR7 carb and he did the standard 110 main that is frequently recommended for most initial CG250 engine set-ups. He got that classic "rich bogging" at 3/4 to full throttle. He pulled the plug and it indicated a rich condition. I forgot to ask him what elevation he was at (we did the carb tuning via FB messenger video chat). I then asked, "What elevation are you at?" His response: "Huh, dunno." He checked and it was @ 300'. His elevation definitely wouldn't work with the typical go-to initial carb set-up for most CG250 dual sport riders here in N. America.
His bike runs well with a 103 main jet due to his elevation being lower (on average) than most who own & operate the same bike. Based on what you've said, I suspect your main jet is still too rich. (1) If you are bogging primarily from 3/4 to to full throttle, that is the throttle range controlled by the main jet. (2) Idle to 1/4 throttle is your pilot system (pilot jet, fuel-air mixture screw). (3) Mid throttle is controlled by needle & needle jet (1/4 to 3/4 throttle). Re: # 3 above, the needle jet is the long, tall brass thing that the main jet screws into and it is what the needle (the tapered, long flat round thing) sits into. We normally don't change the needle jet on our Chinabikes, but it's helpful to know what it is when studying carb mechanics and how to tune your carb. The needle sits down into the jet needle and the needle raises up and down within the needle jet when you twist your throttle. As you probably already know, you *can* adjust your needle. Moving the e-clip further up on the needle makes your needle sit further down into the needle jet and limits the amount of gas that is let into the air-fuel mixture, thus leaning the air-fuel mixture out. Lowering the e-clip on the needle makes your needle sit higher up, thus allowing more gas to enter the air-fuel mixture, thus enriching your mixture. Again, most of us don't mess with changing our needle jet, but we change the height of our needle via the e-clip to tune the mid-throttle range (1/4 to 3/4 throttle). Nevertheless definitely follow the advice you've already been given or you'll be chasing your tail forever trying to figure it all out. |
in case your wondering... yes, i put 19" on front and 16" in rear... it really brings this bike up to a mid size enduro kinda.. it came with 17\14
#8 | |
Have Fun!
Hope you have some fun now! I can't wait to get mine up on some mountain trails at the end of the month. It is quicker than my TT250...which makes sense only 4.26 hp less but 145 lbs lighter.
