07-11-2020, 04:25 PM | #1 |
Hawk bent the clutch lever
Long story short bike fell over when I was looking for something I already own instead of buying it again, bike fell over due to soft asphalt broke my top box and bent(!) my clutch lever. SOOOOOOOO I have seen a couple of posts about CB500X/F 2013-15 levers and a bunch on replacement amazon/ebay specials (https://www.amazon.com/dp/B07D72VYRQ...ing=UTF8&psc=1) but I had a question that hadnt occured to me till I saw another (unanswered) question in another topic. The clutch safety switch. The amazon ones dont mention having one so if I went this route how do I bypass is it just connect them together or something more complicated. I saw that a couple of seasoned guys (Jerryhawk250(? doing this from memory and cant get back without losing this) for one).
Thanks in advance.
Toys include Audi B7, running Stage 2+, S4 Brakes. My VW Vanagon is running 2.5l VVT Subaru engine, 18" AMG wheels, Porsche 944 Steering Wheel, W eekender interior. 1989 VW Vanagon Bluestar one of 2500, 1986 Honda Shadow, 2000 Suzuki Intruder, 1988 Kawasaki Voyager XII, 1976 Mercury Capri II, a bunch of Trailers including a shortened Vanagon for camping, a Sequoia and the latest addition a 2019 Hawk 250. (But dont tell the wife! ) (Latest latest addition a 1995 fwd Subaru SVX) |
07-13-2020, 10:15 AM | #2 |
the amazon ones has the switch (help to have glasses on when you look at picture, age!!)
07-13-2020, 10:18 AM | #3 |
Those are the same levers i have on my hawk. Work perfect.
07-13-2020, 11:05 AM | #4 |
Does the lever mounted throttle adjuster work better then stock? OE Hawk adjusters need to be darn near falling out to get close to acceptable free-play.
Nice that these are length adjustable too. |
07-13-2020, 11:14 AM | #5 |
The levers are separate from the throttle.
07-13-2020, 10:40 PM | #6 |
Oh! I guess I should look more closely. I thought for some reason the throttle cable adjuster went through the lever perch.
07-14-2020, 02:48 AM | #7 |
If it's not snapped, you can heat it up with a torch and slowly bend it back with a box end of a wrench slipped over the lever. That's what I always do.
07-14-2020, 02:21 PM | #8 |
Its rideable as is, but once the new ones turn up I will try heat and a wrench. Didnt want to snap it of and be lever less :-)
