Old 04-11-2008, 01:29 PM   #1
bronevaya   bronevaya is offline
no muffler, how to cope?? (for now)
so I dont have a muffler (despite my bike coming with two)
I ordered one from a member on here, but its apparently lost in transit and now I have the post office looking for it :(
when I ride it now I get a lot of pops and bangs like its running lean. I have the carb screw backed out a bit (not too much though) and I have a flexible pipe running from the mid pip to the back.
is there anyway to make it run decent for now?
midrange I have a lot of stuttering like it wants to die.
Old 04-11-2008, 01:35 PM   #2
red2003   red2003 is offline
That must be some freakin loud! It wont do any permanent damage to run it like that, but more then likely that is the source of your pops and bangs. Air is leaking into the "mid pipe" and popping. It's proabbly gonna be out of tune until you get a muffler on it, btu it shouldn't make it die because of a lack of one. More then likey you got junk in the carb. I'd pull it off and give it a good cleaning. Raise the needle up while you are in there, turn the fuel screw out two turns from fully closed. That will help your mid-range studder.
Old 04-11-2008, 01:47 PM   #3
I cleaned out the carb and moved the clip up already.
I also believe the carb screw is 2-3 turns from close position. I can start seeing some of the threads on the screw.
Its very loud, but I also see it as a safety factor as cars can now hear me.
I also wrapped the end of the pipe in silicon (high temp stuff) and slid the flexible pipe on top of that.
Old 04-11-2008, 01:47 PM   #4
katoranger's Avatar
The open exhaust is making it run very lean. Been there done that.
The suggestions red gave should help, but you may want to try to make some kind of a restriction/baffle on the end of the flex tube.
Possibly a cheapo riding mower muffler.
Allen
Old 04-11-2008, 01:52 PM   #5
maybe I just dont know how to search, but can someone find me a cheap-o exhaust made for china bikes on ebay? I also remember seeing a whole exhust system too. (that might have been on ebay.ca though)
Old 04-11-2008, 02:01 PM   #6
katoranger's Avatar
I would try to find an exhaust from a honda of similar size like a crf or xr.
Allen
Old 04-11-2008, 02:10 PM   #7
thing is, I want the muffler with the pipe leading to the mid pipe, the welding shop wants too much to weld some pipes together
Old 04-11-2008, 02:20 PM   #8
Dragon   Dragon is offline
Buy ear plugs.
Old 04-11-2008, 02:29 PM   #9
oh, I dont care about the sound at all
just the stumbling/sputtering
Old 04-11-2008, 02:45 PM   #10
katoranger's Avatar
You want a complete exhaust then.
The head pipe from an early 80s xr200 will probably fit.
Did you post in the wanted parts yet?
Allen
