04-11-2008, 08:09 PM | #1 |
went for my first legal road ride
Just got my motorcycle liscense today and took the gy5 for a ride. went about 5 or 6 miles and the bike bogged and died on me while going 50 mph. Then wouldnt start back up again. I played with it a bit and finall got it to start poorly with the choke on but then it would die again. It sat for about 15 min with me tinkering with the idle and air filter and wires and such looking for a problem then it started again ran fine for about 100 yards then did the same thing but worse. this time the engine kinda locked up a bit but then spun again but would not start again. So i got a ride back to the house got the trailer and picked it up. Brought it home and the thing runs fine now. I think it over heated. but while cruising at 50 mph for maybe 3 minutes? I am very disappointed with this thing. i have been riding it offroad with no problems at all for weeks in situations where an air cooled engine would get much hotter and i have not had a problem. Any thoughts?
04-11-2008, 08:27 PM | #2 |
Did you change out the cheap Chinese oil?
04-11-2008, 08:31 PM | #3 |
yes just changed the oil maybe 25 miles ago. And it was changed when it was first purchased by me. It only has 415 miles on it. It might be a touch low on oil i put in a quart.
04-11-2008, 09:26 PM | #4 |
Almost sounds like a coil issue?
04-11-2008, 10:18 PM | #5 |
i would bet there is some junk in your petcock or carb.
04-11-2008, 10:26 PM | #6 |
do you have gas in it? yes, a very stupid question, buts it has happened to lots of people. these things get such good gas mileage that its just something we forget sometimes
04-12-2008, 09:03 AM | #7 |
Yes i have gas in it. The coil was also a thought that i had. But the fact that it would start with the choke on kinda made me steer away from that. It was very foggy out and i shouldnt have been riding it as i had to wipe my goggles off every thirty seconds. I live on the beach in new jersey and the air corrodes everything here. Maybe it was the coil connections.
04-12-2008, 09:06 AM | #8 |
Yup, sounds carb related to me. Pull the tank and carb and clean everything out. Probably a piece of crud in there obstructing the flow. Off road, you are on and off the gas and probably it was flowing enough, but at a consistant 50 mph, you're running a lot of fuel through it. Also check for a kink in the fuel line. Relax, it's not anything major. These bikes require tinkering for the first few hundred miles. I worked on my Roketa more then I rode it for the first few hundred miles. I now have 2000 miles on it and do nothing but change the oil and run it.
04-12-2008, 09:35 AM | #9 |
While you're working with the fuel system and carb, grab a cheap "see-thru" fuel filter to put in line beteen the petcock and your carb so you can worry less about junk in the fuel or carb in the future.
Even if it isn't the problem now....they are a really cheap way to help prevent trouble down the road....but I would agree with what's been said, it sounds like a fuel issue. Is it possible it was running rich and eventually overloaded the carb? It almost sounds like it was flooded for a bit....but maybe not. My experience is limited, so I could be way off base. 8O Good luck getting it sorted.
2008 American Lifan LF200 GY-5 (930 km) - Sold 2007 Kawasaki EX250 - Sold 2006 Kawasaki EX650R - My new ride! 2005 Kawasaki EX250 - A new project |
04-12-2008, 09:40 AM | #10 |
Sicky overhead cam
Back in the 70's my Honda SL100 would do that occasionally due to the overhead cam locking. Just toolin around in the sand pits i wouldn't have a problem, but during a more extended high speed romp, the problem would appear. :x
In my case there was some small debris (paper towel bits) that kept blocking the tiny oil passages to the cam. You might want to give the engine a good flush out with a quart of clean oil. I would put her in gear and back up to rotate the motor backward backflushing the passages and dump the oil hoping the debris would clear out. How's the screen been looking? It's recommended that OHC bikes use only the finest grade motorcycle oil and change the oil more often to avoid this problem. If the head's bearing surface is badly scared, the head may need replacement. If the problem continues, i'd pull the cam and check it for damage.
Wayne Wildfire WF300-SP |
04-12-2008, 09:42 AM | #11 |
Make sure you gas cap is venting too.
Try removing the cap if it stalls and then see if it runs better without it. Allen
04-12-2008, 11:10 AM | #12 |
I'm gonna side with katoranger but all advice has ben good.
Try this: Get a clean GLASS jar that you can store or throw away after using. shut the fuel petcock off then pull the fuel line from the carb place the GLASS jar under the fuel line to catch the fuel so you can monitor the fuel flow and reuse the fuel open the fuel petcock and let the fuel run for a couple of minutes it should flow consistantly and not slow down at all if it slows down remove the fuel cap if it then speeds up the fuel cap vent is most diffinitely clogged if it slows down and the still runs slow after removing the fuel cap then there is a blockage in the fuel petcock prescreen filters I'd also have to reccomend upgrading to real fuel line and an inline fuel filter if you have a good supply of fuel to the carb then there could be a problem in the carb if the fuel system checks out then start looking at the electrical (YUCK) |
04-12-2008, 01:01 PM | #13 |
spark plug is where I would start.
04-12-2008, 04:18 PM | #14 | |
It's the part about the engine locking briefly that makes me worried about the cam going dry. :wink:
04-13-2008, 08:03 AM | #15 |
did it actually lock up though or were you in too low of a gear for the speed you were traveling when it quit? if it locked up, the rear wheel would have slid, until you came to a stop.
