Old 07-27-2020, 07:46 PM   #1
stang07   stang07 is offline
Hawk 250 shifter position switch
Does anyone know where I can source a shifter position switch for a Hawk 250? I upgraded to the digital cluster, and 4th and 5th do not show up. It worked fine, for a while, although 4th has never worked.
Old 07-30-2020, 05:53 AM   #2
NzBrakelathes's Avatar
Earth the wires to see if it’s not those
I may have 1 is it 1 or 2 bolt style?
Old 07-30-2020, 09:56 AM   #3
I did, and they still didn't light up in the cluster. It is the two bolt style.
Old 07-30-2020, 10:15 AM   #4
Mudflap   Mudflap is offline
If the indicator didn't light up when you grounded the wires then it would likely be an open circuit between the indicator light and the switch.
Old 07-30-2020, 11:14 AM   #5
I figured it out! Two wires had pulled loose from the connector for the main harness. I pushed them back in and now it works perfectly!
