11-23-2020, 08:50 PM | #2 |
Might try a rotopax.
11-24-2020, 01:35 AM | #3 |
For purely aesthetic reasons, I'd love to see what tanks could be installed on the Hawk 250 or DLX... I don't like the look of it on mine right now as I removed the plastics (they pretty much always misalign anyway) and it looks 'better' but kinda dumb.
11-24-2020, 05:42 AM | #4 |
I agree, I'd like to find a smooth tank without the holes for the plastics that extend to the front. Make it look more like an old Xr honda.
11-24-2020, 05:52 AM | #5 |
You'll have to do some research, but when I was kitting out my DR, I used these guys almost exclusively: https://procycle.us/model
They have a whole bunch of options, and you can sort the page by model. Since these bikes seem to be a mish-mash of designs, you should be able to find something that works. Hope this helps!
11-24-2020, 07:48 AM | #6 |
anything can be made to fit.... if you can do a bit of fab work.... i swapped the 1.1gal tank from my Roketa/Shineray with a DR650 3.5 gal tank and seat... someday i may pick up an even larger tank for a dr now that i know it works....
EDIT: heres the thread where i did the mods... http://www.chinariders.net/showthread.php?t=13250 |
11-24-2020, 10:12 AM | #7 |
I sold the factory tank from my DR to one of the forum members here. Same thing, a cutting torch, some flat stock, and a drill later, he had a tank that was three times the size of his stock tank. Just be patient with your measurements and see what kind of room you have to work with, and finding a tank that can be adapted to fit shouldn’t be a huge issue.
11-24-2020, 10:22 AM | #8 |
Here's a link to Blackbikes thread of the install. http://www.chinariders.net/showthread.php?t=18291
11-24-2020, 10:22 AM | #9 | |
