Old 11-29-2020, 01:56 PM   #1
chuckyboy402   chuckyboy402 is offline
Doh! HELP cant figure out where this part goes
im working on a 107cm3(110cc) atv motor with reverse and when i took the clutch cover off i had this part in the bottom of the case and i cant locate where it goes? Also i had oil coming out of the stator side of the motor out of a bolt hole. i have the location circled in red on the image of the motor
Old 12-06-2020, 12:46 PM   #2
Oil leak
oil is leaking pass the gaskets... put some permatex # 2 on the threads and put the bolt back in.. the piece you found is just a hole cover plug... to keep dirt and stuff out... if they do nto use that hole... jus t to MAKE IT LOOK PRETTY...
ABIBABA ATV ETC
