02-09-2021, 12:09 AM | #1 |
70cc quad breather to air filter question
Hello, I got rid of the stock air filter, it had a crank case breather hooked up the the air filter to the crank case.
I have switched to a pod filter, is it safe to just leave the crank case breather dangling or should i cap it off or find a small filter for the end of it on the engine? |
02-09-2021, 07:26 AM | #2 |
just put a vent\filter on it. dont cap it off. did the same on my 125cc quad and mb200-2 minibike.
02-09-2021, 04:53 PM | #3 |
vent
just do like before on the NON EPA motors.. put a hose on it to breathe .. try to turn it away from the motor... downward..... but do not KINK IT.. that will blow the seals if it can not breathe..
02-09-2021, 07:43 PM | #4 |
If I just turn it away from the motor wont dust/dirt get sucked anything get in the engine? Do I need to get a filter for it?
02-09-2021, 11:53 PM | #5 |
Put a fitting on your new air filter and run the hose to it. Then you can burn the crank case gases (smog) as intended by the air box designers. Our 125cc came set up this way from Tao Tao. Here's an example of what it looks like.
https://smile.amazon.com/Approved-Fi...%2C223&sr=8-20
