Softer seat modification?
Ok I read some where on the web a while back (I can't find the siite now) but a guy drilled holes in the Seat Foam of his seat in order to make it softer. I am guessing the holes release some of the pressure in the foam....
I was thinking about just drilling a bunch of small 3/16-1/4 holes all in the foam on the sides and on the top... Has anyone ever heard of this? I am thinking about giving it a shot, since I am planning on changing out the Seat Cover sometime in this week/weekend. When I do it I will post plenty of info with pics....
-2005 Sierra SR200- |
I just want to modify my seat to make it wider. Then recover it with vinyl.
Allen
Good idea. Makes sense to me. More holes = more air space = less dense foam. Go for it, and let us know what you find out.
drill them towards the bottom of the foam...3 roys up and a whole every 3mm...
I did this with the seat that is currently on my GY. While it helped a little I'm
not sure it was worth the time and effort doing it. I made a cutting tool out of 1/2" copper pipe and twisted it by hand to cut out the foam. I do have pics, but can't seem to locate them at the moment. The crummy foam is really the problem. I would like to find a decent used seat that I could transfer the foam to this seat and reshape to fit the cover. Maybe one day. Here is the link you were referring to... http://www.thumpertalk.com/forum/sho...d.php?t=489610
2000 MZ Baghira |
Thanks I knew I saw it....I thinking I might try it still....My seat is Really hard...and the bike has about 400 miles on it...
IMEazy-Reynolds is changing his seat cover anyway.
I should have listen to ImEazy
....I got everything off, driled the holes, that was the easy part, Now I don't have a powerful enough Staple gun to put the New seat cover on....The plastic seat pan is pretty stiff....Any Ideas???
Tool rental? Maybe an air stapler?
#10 |
Well I called around and it is $25-30 to rent the tool...I found an upholstery shop that will put the cover back on for $35...so I will just drop it off with them and let them re cover it...
#11 |
well here's the before and after photo's of the bike. I really did not like the Blue. and the New Seat cover is softer and more durable material...
before ![]() ![]() after ![]() ![]()
#12 |
Looks nice and comfy...
#13 |
The seat definitely looks better in black. I am lucky when it comes to
recovering things as my dad is an upholsterer and has all the proper tools to due this stuff. We have redone both of the seats I have multiple times and pretty much done with them as the plastic seat pans have so many staple holes that doing them again will probably kill them. Have you noticed a difference with the holes in the foam? As stated before I don't think it made much difference in mine.
2000 MZ Baghira |
#14 | |
It was a little softer,but not worth the headache......I think you it would be easier to do the the walmart gel Atv Seat cover Mod.
#15 |
But it is so hideous!
but saves the 'roids! :?
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
