Old 04-04-2021, 12:34 AM   #1
Roadragon   Roadragon is offline
An update on my KP mini. (Help? Anyone ever had a similar problem?)
Ok so I turned the idle screw on my kp up and she ran!!! But still somewhat rough and at a very high RPM. What should I do? Carburetor blockage? New carb? Re jet (and how?) thanks y’all! Here is a video of the problem:
Old 04-11-2021, 09:38 AM   #2
oincman   oincman is offline
Check the obvious things first, plug and wire. Make sure the throttle cable is binding on anything. Make sure the choke cable isn't sticking. Check your Air/Fuel screw and Idle screws.
Check your valves for proper clearance (engine needs to be cold).
Old 04-11-2021, 09:44 AM   #3
franque   franque is offline
To clarify, cooled off overnight.
Old 04-11-2021, 09:52 PM   #4
Where is the air/fuel screw on the kp mini? I’ll check throttle. Choke cable is fine. Valves... well I may have to have someone do that... I’ll check the spark plug and wire too.
