Old 05-07-2021, 02:26 PM   #1
Topbench   Topbench is offline
Vitacci Raven 250BSR exhaust mod
Hi All, does anyone know if the new Ravens will take the same exhaust mods as the Hawks? Thanks
Old 05-07-2021, 03:38 PM   #2
Yes it will.
2004 Honda ST 1300
Old 05-07-2021, 09:16 PM   #3
Thanks For all the support JerryHawk.
Old 05-17-2021, 09:38 PM   #4
I installed the new exhaust tonight. This was the link skyd and MegaDan have mentioned. Bolted right up front and back. The back lined up with the frame bolt. The middle mount was offset and also needed a 1/4 rubber spacer and tapped hole.
Old 05-18-2021, 04:02 PM   #5
stewbrash's Avatar
We want to see pictures, or it never happened! I just received a blue BSR 250; (Vitacci is no-where on the MCO...it says CHONGKING ASTRONAUTICAL BASHAN as the manufacturer, the make is a BASHAN, and the model is a BSR 250!) Jeez...I just don't get it with all the BS, scheming and misrepresentation! Will document my experience shortly...I want to receive the paperwork from the vender first. There was ZERO damage and no birth-marks!
Old 05-18-2021, 11:06 PM   #6
I will post photos when I can open the forum on my laptop and figure out how to post. I need arm extensions to work off this phone. I do know that I could use suggestions on a carb recipe. Had it tuned pretty good before the exhaust change. Seemed lean in the pilot at 27.5, I tried a 32, way too rich, moved back to 30 and still too rich. I will check the valves again and move back down again. Any suggestions would be welcome. Thanks.
Old 05-25-2021, 09:18 PM   #7
I will give the photo attachment a try. It took me awhile to get the carb recipe dialed in but I am loving it now. The pipe routing was far enough away that it hasn't bothered the air box. I have ordered some reflective tape just in case but it hasn't showed up yet but it doesn't seem like it will be needed. The muffler mount landed perfectly on the frame mount hole. The mid mount support lined up pretty good with a 1/4" gap, perfect for a rubber spacer. Well worth the few extra Benjis.
Old 05-25-2021, 09:21 PM   #8
Old 05-25-2021, 10:14 PM   #9
stewbrash's Avatar
The green looks awesome! The websites that sell these really need to post better photos!
