CRF style exhaust..
So - was looking and looking and finally decided on the CRF230 pro core style exhaust to put on my X-Pro 250 Zongshen.. and it doesn't fit! When the flange is seated on the exhaust port under the frame and all, it's crooked and I can't manipulate it to fit right. The only flush fit is when the pipes are outside the frame and then it's a good bit away from the bike - and the muffler hookup doesn't line up in the right spot..... I do not have a middle bolt holding the exhaust in place, just a solid pipe from the engine to the muffler, which doesn't seal around the muffler either.
Just wondering if anyone has any advice on getting this fit right? I took just the pipes into a local 'custom shop' and immediately was told no, or something like they didn't want to or some BS.. Or am I better off just cutting and gutting the stock pipe? I do have a MIG machine, no gas.. not sure if this would turn into a disaster that I won't be able to fix lol
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
I took mine to a tree with a 3 foot 1/2" extension, a jack handle, shovel handle and other things to bend, beat and pry into a configuration that kinda works. It could still use some improvement.
I had to reduce the radius and lift the end that goes to the muffler. It was sketchy and involved constant fitting, but that stainless steel pipe is stronger than I initially thought. Drilling the holes was easier than I thought as well, but I had access to brand new Clee-Line 1/2" bits even though I only used one. |
https://www.orionpowersports.com/sta...-223cc-engine/
So I just came across this - and ordered it.. will update when it comes in and I get it on the bike.. Can't believe that I missed this somehow. All pics are exactly like my bike, so should be the way to go. I will have an unused Pro Core CRF230 exhaust if anyone needs one on the cheap! ![]()
#4 | |
