Old 08-09-2021, 10:12 PM   #1
MN-Chonda   MN-Chonda is offline
Tao Tao 110 ATV Parts Question
I bought a 6 year old tao tao that had maybe 10 hours on it and sat in a shed. Previous owner bought it for his daughter and she used it twice. Carburetor was junk so I got a new one on Amazon and it worked good. Kind of took a few heating and cooling cycles to quit all the oil leaks from dried up gasket.
So fast forward. I used it for fun (250lb man!) and ended up breaking the steering plastic washer. I got it replaced and checked all bolts and nuts for tightness, including replacing cotter pins. I went to torque the exhaust manifold bolts because I had a slight exhaust leak. Well one of them snapped off with only 1/4 flat from tight. I love Chinese metal......
Anyways I had to drill the stud out and got lucky without damaging the threads until I accidentally drilled all the way thru. Now she leaks oil from that stud on the exhaust manifold.
I need to buy a new cylinder head for it. I found this on Amazon GOOFIT Completed Cylinder Head for 4 Stroke 110cc Engine for ATV Go Kart.
Has anybody used one of these and how did it fit?
My atv only has forward gear, how do I tell if I got the 110 cc vs the 125 cc?
Thanks
