10-19-2021, 05:10 PM | #1 |
2020 hawk deluxe turn signals
Went for 70 mile trip to Lancaster and the next day neither of my turn signals work front or back everything else like lights horn work, trying to read the wiring diagram is not to easy, do they have a separate fuses
10-20-2021, 09:03 AM | #2 |
What does "deluxe" have to do with it?
Sounds like a wire simply unplugged. |
10-20-2021, 10:48 AM | #3 |
Who’s to say the model don’t make a difference it didn’t really hurt you for me to add that and if it did IM SORRY
10-20-2021, 11:09 AM | #4 |
It may be just a bad flasher or bad connection to the flasher. Check that you are getting power at the flasher unit.
10-20-2021, 12:30 PM | #5 |
Thank you for your professionalism in this what I thought was amateurs coming for help from people that might be able to help without belittling other members I will check that out hopefully it that easy of a fix,
10-20-2021, 02:27 PM | #7 |
He is referring to the Hawk DLX / Deluxe, which is a different model than the standard Hawk.
10-20-2021, 05:23 PM | #8 |
It’s not the plugs under headlight , I take it the flasher is under the seat
10-20-2021, 05:32 PM | #9 |
That's were it is located on the standard Hawk.
10-20-2021, 06:23 PM | #10 |
Where can a new flasher be bought providing it’s the same as a standard hawk
10-20-2021, 08:27 PM | #11 |
You say dlx I say deluxe,,,, You say potato, I say potahto
10-21-2021, 07:45 AM | #13 |
Its a standard universal flasher that you can pick up from any auto part store unless you have LED turn signals, then you will need one for LED. Bring the old one with you and they will match it up.
10-22-2021, 05:22 AM | #14 |
Thanks it was the flasher, I went to three different auto supply places and could not find the same looking part , I took a chance and got a round one the plug looked a little wider but it works good, thanks for your help, That’s why I come here to learn and give others what ever I have experienced with my bike.
10-22-2021, 07:34 AM | #15 |
Glad to help. The shape of the flasher doesn't have to be the same as long as the prongs are correct.
