Hawk DLX, 1300 mi., few issues
I just passed 1,300 miles on my Hawk 250 DLX last week and just recently noticed two issues--the first issues I've had with it.
2022 KLR650 2021 Hawk DLX 2021 Lifan Xpect 2021 Hawk 150 (RPS Viper) |
#2 | |
These engines are a 67mm bore stock. There are no big bore "kits" out there. The closest you get is a CG300 Cylinder kit, which does exist with all gaskets, piston, etc. The CG300 has a 70mm bore, which when installed on a CG250, makes an actual 249cc engine. It does, however require machine work to actually be fitted to the engine. If all you want to do is stop the leak, then get a base gasket and a head gasket set. Those gaskets on these engines are super easy to replace.
Re: Your ignition switch. Before dropping any coin on replacing it, I would hose it down thoroughly with electrical contact cleaner. If that does not do it, take it out and inspect the solder points on the bottom. Ensure that none are loose or cracked, and if they are you can resolve that by poking them with a soldering iron to remelt them. I've never in my life met an ignition cylinder with flaky electrical contact that could not be cured.
Replacing the cylinder also entails replacing your gas cap and helmet lock, which I see the CSC set comes with but it's still an extra pain. You're going to have to take the cylinder out anyway, so you may as well clean and inspect it first. |
#4 | |
Mainly just turning down the OD of the cylinder sleeve protrusion at the base to the same.OD as the 250cyl. I just wanted to make that point clear for others that might read the thread because misinformation is rampant and abundant.
Boom. That did the trick. Last week I flooded the key hole with contact cleaner and exercised the key about 20 times. I haven't had a cut-out since.
