Old 02-11-2022, 06:30 AM   #1
mikegolf   mikegolf is offline
Charging battery through 12V cigarette plug?
I assume the 12V cigarette plug is wired directly to the battery, there is no voltage stabilization. I know there is a fuse, but the charger maximum output (3A = ~40W) is way below the fuse rating.
I'm looking for a way to connect the charger easily ... how bad is it to connect it through the 12V outlet? (Ignoring the fact I'll have the male plug on the charger output)
During the winter time (this means mostly rainy ~0 to 5* C weather) I need to charge the battery quite often - but still don't want to take it out, so when there is a short weather window, I can go riding.
Old 02-11-2022, 07:17 AM   #2
I would think that it would work to slow charge or trickle charge without an issue. Worst case it'll blow a fuse.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 02-11-2022, 08:54 AM   #3
Lukas   Lukas is offline
There is a simple way you buy furukawa plugs as they are in the motorcycle and make a splitter, and that's all without combinations and without bleaching the installation I did so.
Old 02-11-2022, 04:16 PM   #4
Oldenslow   Oldenslow is offline
I have a trickle charger that has the option of using an SAE connector. Each of my bike batteries wears an SAE pigtail so I can plug/unplug quickly as needed.
Old 02-11-2022, 05:43 PM   #5
zero_dgz   zero_dgz is offline
I don't see why reversing the flow like that on the socket wouldn't work. There are already gadgets for maintaining car batteries that work this way. Is the socket not switched with the ignition key, though? I would test that first.
Old 02-14-2022, 05:55 AM   #6
You are right, the outlet is active only when ignition is on.
I guess I will attach the dedicated connector to the battery just for charging. I need to figure out how to protect the + wire ending, as my charger has crocodile clips only...
