02-23-2022, 11:40 AM | #1 |
Tau Tau quad front brake and spindle
Just received a new spindle and brake assembly but the brake assembly does not want to go on to the spindle,
Any thoughts? Thanks |
02-23-2022, 11:46 AM | #2 |
Please post pictures. They will help us to understand what you're dealing with.
02-23-2022, 01:14 PM | #3 |
Tau tau quad brake and spindle
Nothing fits
02-23-2022, 01:27 PM | #4 |
Did you buy this as a set? The drum should fit tight on the shaft and may need to be pressed on unless you where sent the wrong size drum to fit the shaft.
02-23-2022, 02:00 PM | #6 |
That's what i would do.
