Old 03-06-2022, 02:34 PM   #1
Dusman   Dusman is offline
Brozz engine in Hawk frame?
Does anyone know if the Brozz 250 motor will fit in the Hawk frame? I ask because it seems that the counterbalanced motor of the Brozz may have fitment issues.
Old 03-06-2022, 03:00 PM   #2
Won't fit due to the counter balancer. The frames on the Brozz and TT250 are kicked out more at the bottom of the frame up front to make room for it. Now a couple of the newer gen counterbalanced OHC engines, like the RE250, will just barely fit with just a little love from a hammer on one spot at the very bottom of the frame. They do require relocating the lowest motor mount tabs though, so a little welding is required. The upside to the RE250 is also an extra gear.
Old 03-06-2022, 04:34 PM   #3
That’s what I suspected. Thanks Dan.
