04-12-2022, 09:06 PM | #1 |
oil Lowes 4 cycle non synthetic
ok pulled the trigger - 2016 CSC TT250 750 miles &
QUESTION can i use 10w40 4 cycle not for autos non detergent non synthetic i know for the clutches thank you very much |
04-12-2022, 09:39 PM | #2 |
Detergents aren't the problem, most 4t oils contain quite a few including some to keep particles in suspension.
Synthetic isn't the problem. I run synthetic in all my bikes, Motul 7100 in my vfr and Rotella T6 15w40 in my Hawk. I even broke my Hawk in with it. No issues. Most guys run Rotella T4 15w40. Works fine. Some guys run Walmart supertech cheapie oil, no problems. what they all have in common is that they have no friction modifiers. A good rule of thumb is if it states it is a high efficiency oil then steer clear. Friction modifiers like moly will cause a wet clutch to slip.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 04-12-2022 at 10:37 PM. |
04-12-2022, 10:21 PM | #3 |
thank you so much hitting the lowes at 9am
https://www.lowes.com/pd/Rotella-SHE...GAL/1003071616 should last till i put in away for the winter |
04-12-2022, 10:25 PM | #4 |
Obviously - I should Never MIX Synthetic with reg oil to top off?
04-12-2022, 10:38 PM | #5 |
that's what a synthetic blend is. No reason why not. Rotella T5 is quite literally a mix of T4 and T6 lol
