Old 05-22-2022, 11:57 AM   #1
GamingRAPTRcom   GamingRAPTRcom is offline
GamingRAPTRcom's Avatar
Grin I found a direct bolt-on exhaust system for my Lifan X-Pect!!!
There were two modifications to the exhaust that needed to be made, but no modifications to the X-Pect or it's exhaust mounts were needed. The sides of the exhaust flange have to be opened with a cutting disc since the Lifan's bolt pattern is a little wider though that's easy enough. Also, you can re-use all the factory exhaust bolts at all the factory attachment points. However, a small 1/8th-1/16th strip of steel you can mark for a set of a set of bolts is the only other thing you need. A slight twist to it will keep the mount tucked under the X-Pect's body panels comfortably. It sounds great and works beautifully!!!
As a side note, there wasn't an exhaust gasket on the factory manifold. I already did the valve adjustment, but there was a slight bit of pre-ignition noise. As it turns out it was an exhaust leak interfering with the oxygen sensor's readings. I used a 2000 degree exhaust seal paste to seal around the header and it stopped the pre-ignition sounds in the valvetrain cover completely. If anyone else still has any pre-ignition issues, which will almost sound lick a light ticking from the combustion chamber. Seal the header with some of this exhaust sealer, it can also be sanded and painted as well.
(Exhaust System) www.amazon.com/gp/product/B07B2DTZ6H
(Exhaust Sealer) www.amazon.com/gp/product/B07GDVKHMN
Old 05-22-2022, 06:04 PM   #2
TominMO   TominMO is offline
Good work and thanks for sharing! Have an extra cookie.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle.
Old 05-22-2022, 06:59 PM   #3
I probably would have just replaced the exhaust gasket in the cylinder head myself. They are cheap. No sealant needed.
Old 05-22-2022, 09:09 PM   #4
drstansbury@yahoo.   drstansbury@yahoo. is offline
did it have the o2 bung?
Old 05-22-2022, 09:42 PM   #5
kevperro   kevperro is offline
Does the X-pect have the same Honda motor as the CRF 230?
Old 05-24-2022, 02:17 PM   #6
I installed a 12mm O2 Bung, the shops will tell you it'll affect the finish. Though an exhaust wrap looks good on it. ^_^
Old 05-24-2022, 05:42 PM   #7
Grin She sounds great!!!
Old 05-28-2022, 05:55 PM   #8
So what experience have you had with increased power from your intake/exhaust mods? Getting up hills, top speed, etc.
2022 Lifan KPX
