Old 06-06-2022, 11:42 PM   #1
Apostle_7   Apostle_7 is offline
New to me X22R
Howdy!
I picked up a 2019 X22R that needed some love. I replaced the cracked intake boot and put a pod filter on it (the air-box snorkel was missing). I have a jet kit inbound as it's running lean. It came with a carbon fiber muffler so that doesn't help with the lean condition I'm sure.
It seems to run out of steam at about 65mph/6200 rpm. I know I need to get a smaller rear sprocket. I want to go 36 or 37 instead of the stock 42.
Who sells a drop in sprocket, or does someone have the dimensions so I can get one custom made?
Thanks!
Old 06-07-2022, 07:48 AM   #2
36 tooth will be the smallest you will want to go with without any issues.
Custom Sprockets https://shop.pbisprockets.com
Center Hole Size. size: 64mm, 58mm if you remove the spacer ring - Size of bolt holes diameter. 10.5 circle diameter through center of all bolt holes: 96mm
2004 Honda ST 1300
Old 06-11-2022, 10:40 PM   #3
Thanks,Jerry! That's what I was looking for.
I changed the jet today from 95 to 105, didn't run well so I switched to 100. Seems stronger but still runs out of steam at about the same rpm. I'll check the plug in the morning and see what gives. Think I'll try the 110.
Old 06-15-2022, 11:03 PM   #4
So I went straight to the 125 jet. The plug was black and fouled, way too rich. I decided to start over and put the original 95 back in it. The slow jet is 38. Runs good again but still starts surging at 6200 rpm. Is this normal?
Old 06-15-2022, 11:18 PM   #5
When engine was stock it ran the best with a 105 main.
2004 Honda ST 1300
